Setting timing on 351 Windsor
Edit: I've found that 36 degrees for the max total timing is around where it should be. Does this sound right and do I measure total timing with or without the vacuum advance
Ok lets sort the terminology first.
Base Timing or Initial timing: is what you set with a timing light on the damper
Total timing; Is the base timing PLUS all the mechanical advance. It does not include vacuum advance.
Ideally, you set the total timing and the base takes care of it's self. Usually, 30-34° is what mild SBF's like. So lets set your dist had 24° of mech advance and your engine ran best with 32° total timing that would make your initial or base timing 8° BTDC.
The timing curve is that rate at which your mech timing comes in See below example of a timing curve with Inital advance and Total. Generally, you want all your advance in no later than 3000RPM with 2500 being better.
Don't worry about 6° or 8° or 12° (or whatever) initial idle timing, because it doesn't really matter too much.
But the total timing is fixed inside the distributor, (unless you want to get in there and modify it) and what you really need to know is where it ends up on the high side, this is the important part.
32° to 36° BTDC is right in there where most every OHV V8 wants to be, so a lot of guys just spool up the engine RPM with the timing light, rotate the distributor housing till the pointer on the balancer is say 34°, and let the initial timing fall where it may. This would be without vacuum advance. The centrifugal or mechanical advance is always set first.
Then take it for a test drive. Without vacuum advance. Accelerate hard full throttle, add a little more timing maybe 1° or 2° if it doesn't ping or knock on hard acceleration. Back it off 1° or 2° if it does. The point just short of knock or ping is optimum for power and economy. Stock OEM distributors may have very stiff springs, or a slow and "lazy" curve. Make sure it's done advancing all the way when you check with a timing light. If you don't check the total timing, it may be excessively "late" or retarded. Everybody knows too much advance is bad, but so is retarded timing. It will tend to run hot, poor performance and economy. If your particular engine combo will run well at 37° total timing, that's what you want. Maybe it's high compression, and will only tolerate 32°. Then that's what you want.
When that's straightened out, then go ahead and re-connect the vacuum advance and take it out again for a quick spin. At this point in time don't mess with the distributor timing, adjust only the vacuum canister itself. Most aftermarket cans take a 3/32" or 2.5mm allen wrench. Listen carefully for rattle or ping again, but this time only at part throttle operation or steady cruise on flat ground. The knock will go away on acceleration when the vacuum advance is excessive.
Crane suggests starting out with the vacuum can at maximum advance (fully clockwise) test driving, and backing off 2 turns at a time as required. Again the general idea here is the same, to have the vacuum advance timing as far out as possible, though just short of any ping rattle. It's OK to have a slight momentary part throttle vacuum advance rattle every now and then.
Crane suggests starting out with the vacuum can at maximum advance (fully clockwise) and backing off 2 turns at a time. Again the general idea here is the same, to have the vacuum advance timing as far out as possible, though just short of any knock or ping. It's OK to have a slight momentary part throttle vacuum advance rattle every now and then.
Most aftermarket distributor vacuum advance cans are adjustable by removing the vacuum hose and inserting the allen wrench. It might take ten full turns or more till it hits the stop. It increases the spring tension and needs a higher vacuum to move the breaker plate and advance the timing.
What you can do before getting it on the road is kind of get an idea of the engine idle vacuum. A stock OEM engine with a factory camshaft will (or should) have a high steady manifold vacuum. If you've a performance camshaft, the manifold vacuum will be reduced and a factory vacuum advance canister may not work correctly. It can get a little involved messing with this but if you take the time to get it right you'll thank yourself everytime you drive it. It's all done with computers and crank position sensors and gee-gaws today of course, but back in the day they only had mechanical weights & springs, and engine vacuum.
Just because the pointer says 10° BTDC on the balancer when setting the initial timing doesn't necessarily mean that's really where it's at. I haven't gone back through this thread, maybe you know this, and have already checked. TDC marks on the balancer can slip because of age for example. This is pretty common.
It all kind of comes back around to the engine basically being just a big air pump, and the carburetor expects and is calibrated for a strong vacuum signal through the idle circuit. Ignition timing has a direct bearing on manifold vacuum levels, if the timing is off spec, or there are vacuum leaks, late valve timing etc., the carburetor will not respond to adjustments and it won't run right.
A factory stock engine with a mild camshaft should pull 19" to 21" steady on a vacuum gauge at sea level, this means the ignition timing and carbutetor and valve timing and gaskets and valves etc etc are in good shape and tuned very close to optimum.
All the newer holleys have backfire protection for the power valve, I am guessing yours does not. One of those backfires may have blown the power valve, that will make it run rich. If it is blown, then it is rebuild time. And you know that carb is not ideal and has been messed with before. I think in one of your other posts you said you had a aftermarket holley 600 that you took off? If you are going to need to rebuild the 750, you might as well get a kit for the 600 which would be a better fit and rebuild it.
What will really ruin your day, if you get the other carb rebuilt and get it running good, and it's still a project in the yard and let it sit for a couple of months, and then you go out to start it and it will not run right again. The fuel you get at the gas station now is lousy and will ruin a carb if it sits around too long. So you need a long term plan if you get it straightened out but are still going to leave it stored. They make fuel treatments that help some.
