F450 Wouldn't Start
Old Apr 18, 2020 | 02:56 PM
KB9OKB's Avatar
KB9OKB
F450 Wouldn't Start
Today our 2019 F450 with 115k mi. stopped running while waiting for a load at Home Depot- which in and of itself is probably fine, it probably just timed out and shut off. But then I was unable to start it. Voltage was good. The starter was cranking faster than normal, for several seconds, and the engine didn't start. I tried again with the same result. I waited longer, pushed the truck out of the way so it wasn't blocking others, and tried again and it started. Perhaps for some reason it was not engaging the engine? Tried it a few more times when I got home and it started normally. Let me know what you guys think, and thanks in advance!
Old Nov 16, 2021 | 07:28 PM
lostru's Avatar
lostru
What did you find out on this issue? I am having the same issue.
Old Nov 16, 2021 | 09:15 PM
KB9OKB's Avatar
KB9OKB
Yes, in our case the engine was shutting off automatically after 30 minutes. Apparently this is the default and you can't restart it until you turn the ignition off and back on again. Hope this helps.
Yaroslava
Mar 12, 2011 09:07 AM
f350fixaliter
Jan 19, 2011 10:44 PM
4x4jedi
Oct 20, 2010 06:20 PM
JECIV1
Dec 22, 2009 08:38 AM
