Replace Body Mounts?
Old Apr 17, 2020 | 07:32 PM
hink10's Avatar
hink10
So, the Ex is at the shop getting a new motor. I thought about having them do the mounts while the body is off but I was there today and they don't look too bad. He said if I did want to replace them, he'd recommend the S&B mounts as the best. They run about $900 for the set and include all hardware. So, I'm already in this for over $16K with the long block, injectors, upgraded intake and exhaust manifolds, up pipes and some other stuff I'm having done while the motor is out. Reason to do now would be no additional labor and peace of mind. I don't really want to spend more money I don't have, but the body is off. What would you do?
Old Apr 17, 2020 | 09:18 PM
JAck19's Avatar
JAck19
Me? I'd do it.
I can't speak in regard to the quality of that brand , but if I had the body up on my truck, I'd be hitting every little wear item I could, front to back. I'd want to give myself the best odds of not needing to lift that baby again. I know the feeling, the point you're at, but this is a prime opportunity to knock out some 15 year old mounts. You don't want to need to do it in a couple more years.
Do it once, and do it right.
Old Apr 17, 2020 | 11:58 PM
hink10's Avatar
hink10
Originally Posted by JAck19
Me? I'd do it.
Yeah, that's my thought too. I'm having all the sensors and wearable stuff replaced while it's out, no extra labor. That's how I got from a $10K long block to $16K+! Granted, I don't need to upgrade the intake manifold, but while it's out. The guy doing the work is doing a good job looking for things. He's never once tried to push me to upgrade anything. He has just taken forever to get going on it, but seems to be making up for it. He's power washing and paining the frame for me. He said he put a newer style fuel pump he had laying around, I think a 6.4 pump. Anyway, my wife asked if it would be pretty much like a new truck, I told her most of the parts will be new! BTW, while I was talking to the guy, he mentioned a coil spring conversion, something I've always wanted to do. He said it really wasn't bad to do and mentioned he had an axle laying around. I may pursue that more!
Old Apr 18, 2020 | 08:32 AM
JAck19's Avatar
JAck19
Here's Nicmike's '07 conversion thread.
I need to regear and I have 37s so the 60 is inevitable. It's just a matter of leafs or coils. If you're staying leaf sprung, going to a Dana 60 is easy peasy.
Old Apr 19, 2020 | 08:47 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
I just did mine. Most of my OEM bushings looked pretty good, from where I could see. However, when removing them, I found the real deal. Not too pretty. Mine cost less than $200 and well worth it. It will also decrease the body wallow.
Old Apr 19, 2020 | 03:56 PM
hink10's Avatar
hink10
Replacing seems like the smart play.
Bgilmore480
Oct 9, 2017 09:02 AM
XC6.0
Mar 9, 2016 05:33 PM
Watcher58
Sep 27, 2015 01:37 AM
shortstuffrm
Nov 25, 2006 09:09 PM
