Brake residual valves for drum brakes???
My truck uses its original 4 drums
I did a complete 100% brake system replacement using a 1967 Ford fairlane dual master cylinder--the MC is for a 4-drum brake car, NOT a disk car. RAYBESTOS MC39495
All wheel cylinders were replaced, and all lines for entire truck replaced--no leaks. I also bought quick bleed valves for fun.
Residual valves are generally only intorduced when using disk brake combos(i have read/been told); and they tell you to check the master for the "little rubber things" and that will tell you if they have residial valves built in. My '67 MC is for a 4-drum car, and the damn thing will not keep pressure...............but I thought residual valves were not needed for drum only vehicles?
I'm tired of pumping my breaks even with a brand new system. Will the installation of residual valves help me?
https://www.strangeengineering.net/u...ressure-valve/
https://www.wilwood.com/search/partn...sidual%20valve
https://techtalk.mpbrakes.com/how-to...valve-overview
With the master cylinder under the floor, below the wheel cylinders, it's even more important to have the RPV's to prevent backflow and wheel cylinder drain.
Residual valves are generally only introduced when using disk brake combos (i have read/been told); and they tell you to check the master for the "little rubber things" and that will tell you if they have residial valves built in.
I'm tired of pumping my brakes even with a brand new system. Will the installation of residual valves help me?
C7OZ-2B257-C .. Brake Pressure Differential Valve / Obsolete
1967 Comet, Falcon & Fairlane with drum brakes. The valves used in all 1967 FoMoCo vehicles were 1967 only!
IF this Fairlane had disc brakes, it would have used a different master cylinder, different valve (C7OZ-2B257-D) and also would have had this puppy mounted on the rear axle:
C7OZ-2B091-B .. Front Disc Brake Pressure Control Valve = 1967/69 Fairlane/Falcon/Comet/Mustang/Cougar.
I actually still have that "splitter" valve thing connected to the brake lines. My dad had a junk '67 fairlane that we tore to pieces. That car is what inspired me to use the 4-drum MC out of a fairlane.
Would I need one valve per wheel or can i just use two valves--one valve per MC output line?
You need this puppy to get the brakes to work properly.
A quick websearch turned this up; your MC may not be for drum/drum after all:
This MC has been frequently mentioned in threads on here, it is for a 68 Mustang with drum/drum brakes: https://www.napaonline.com/en/p/NMAM2036
The front port is the one furthest from the mounting flange, I don't think they meant the port for the front brakes. Now that I look at that question again, I'm not sure they are saying the other port doesn't have an RPV; the guy asked about the front port, so that is what they answered. Look in your ports, should look the same for drum/drum.
DRUM/DRUM MC Ill shows Residual Pressure Valves as 2004 (incl in MC Overhaul kit -
