tank and sending/draw units
Ok boys -n- girls...here's the problem...as I am gathering up parts info to order parts to R+R tank sending/draw units and fill tubes/vent hoses, I am finding this: The available sending/units are for a 3.5 inch opening, the tanks on the 1984 f250 have 2 inch openings. Ok, so just replace the tanks...but all the suppliers indicate that the front 19 gallon tank for a 1985 f250 will NOT fit a 1984 f250. Haven't even asked about the rear tank as it still works, but thinking I'd like to replace the sending/draw unit also while the bed is off the truck. And then there is the possible issue of the fill tubes not being compatible...might have to completely replace all of those components. So...what's a poor boy supposed to do here? I just want to be able to go more than a hundred miles before I have to refuel... I have found tanks on CarParts.com at a reasonable price...
My truck is a 1984 F250 Fleetside 2WD 6.9idi T-19 trans. So, my question is this...will a side mount and rear mount 19 gallon tank from a 1985 F250 work on my 1984 F250? Will I have to change the fill tube neck and other components also? Or will my existing fill tube work. The deeper I dig...the more chit I find...Thx for all the replies!!!
The newer tanks will fit, filler necks and all. The reason they are saying they won't fit? Because the older sending unit is smaller. Of course you knew that. If you get the matching sending unit for the newer tank, you should be good. The only problem you may run into is the wiring plug to the later model sending unit may not fit your older harness plug. I saw the other day that LMC Truck had a whole bunch of wiring pigtails for sending units. But you will probably have to get your new sending units in hand to figure what you need and what you need to do.
You should be buying plain sending units with no pumps, but two fuel connections at the top, since the diesels run a return fuel system.
Ok...gets me closer to the nitty-gritty...LOL!!! Ok, my rear tank is working properly as well as the gauge...is there a method of reinforcing/strengthening that showerhead draw unit so it doesn't break? Thinking I'd take the sending unit out and tinker with the showerhead some ...try and make sure it doesn't break like the front one did.. Thx!!
Oh, suggestion on where to source the sending/draw units? LMC? One of the tank suppliers?
I did not know that!!! Thanks!!! Is that info on a sticky somewhere? Might be a good idea to add it...
I don't know for sure, but I would think if your supply is 3/8" like mine is all the way up to the engine, you would think the pickup in the tank was 3/8" also. But you never know. Most guys don't bother with those shower head pickup units, the originals are famous for breaking off inside the tank. Most people just get submersion rated fuel hose, cut a short piece and put a vee in the end of it and let it be the pickup with no screen.
Mine is broke off my rear tank now, it runs out of fuel right below 1/4 tank. I can only get 10 gallons in it at the station. One of these days I will get in there and pull it out.
This way it will not suck up junk and have issue with sucking up fuel.
Dave ----
