Electric brake controller
Old Apr 16, 2020 | 11:34 AM
lotus386p1's Avatar
lotus386p1
I have a 2003 E450 V10 ford Class c motorhome . I am trying to hook up the electric brakes.I can not find where to plug the controller in . please send pics,
Old Apr 16, 2020 | 11:37 AM
SpencerPJ's Avatar
SpencerPJ
This short video will show you more than you thought you needed to know. From wiring the brakes, to plugging the controller into the fuse box
Old Apr 16, 2020 | 12:04 PM
lotus386p1's Avatar
lotus386p1
electric brake controller
I have watched this video over and over it says there are 2 plugs I can only find one it dont have the right color wires.
Old Apr 17, 2020 | 08:56 AM
SpencerPJ's Avatar
SpencerPJ
So that we are talking the same tune, the controller is the devise you install in the truck that will control the electric brakes of a trailer you will be pulling. It is explained how to connect to your specific E450 vehicle starting at minute 5:09 in video. You will need to buy the specific harness for your E450 to plug to your specific controller. (Etrailer.com is a great place to get this and any other help as well, they have great phone support as well) This is all under the assumption that you have the typical factory installed 7 pin connector on the back of your RV, to plug the trailer into. Should look similar to this. 7 pin connector. If you do not have the prewired 7 pin connector on the back of your E450, who knows, you might have to wire the controller from scratch, but it should be covered with your instructions or available online. Let us know...
Old Apr 17, 2020 | 09:37 PM
lotus386p1's Avatar
lotus386p1
It had a 4 pin on back of RV . I gave up on the easy way. I am pulling wires
to the back. Thanks for your help.
Old Apr 18, 2020 | 09:17 AM
SpencerPJ's Avatar
SpencerPJ
You possibly can only run the brake wires and tap into everything else with the 4 pin. Good luck
Old Apr 19, 2020 | 07:43 PM
lotus386p1's Avatar
lotus386p1
I ran a the brake controller wire and a charging wire and used the 4 pin for the rest . Everything is working great test drove today. Thanks again.
mclarengts
Jan 20, 2013 08:33 AM
iggy2
6.2L V8
Feb 28, 2011 07:27 AM
bama210
Modular V10 (6.8l)
19
Mar 13, 2009 10:58 AM
Jay94250
Apr 27, 2006 01:34 PM
wreckerboy
45
Oct 2, 2005 07:15 AM
