Help
Old Apr 15, 2020 | 01:09 PM
Julia Crane's Avatar
Julia Crane
Help
Help I am replacing my HPOP on my 06 6.0 super duty , when I did the air pressure test I found a leak on the back lower port . Is this a bleed off vavle or is it supposed to have a plug ? I need to know before I put it back together .
Old Apr 15, 2020 | 02:21 PM
SmackDaddy's Avatar
SmackDaddy
Post a photo if you can.
Old Apr 15, 2020 | 03:02 PM
npccpartsman's Avatar
npccpartsman
Are you sure the HPOP itself is bad? Typically on the 05 and up trucks it's the HPOP fitting between the rear of the pump and the block that's bad, not the HPOP itself.
Old Apr 15, 2020 | 05:07 PM
Julia Crane
HEY SMACKDADDY I had 2 bad injectors. HPOP wasnt the problem I just wanted confirmation that the lower rear port is a relief valve. Lol the last engine I rebuilt , the "snap to fit" fitting flew off and broke the back aluminum plate all caused by the factory oil cooler being clogged with casting sand . Really bad chain reaction.
Old Apr 15, 2020 | 05:23 PM
SmackDaddy's Avatar
SmackDaddy
Glad you got it lined out!
Old Apr 15, 2020 | 05:44 PM
bismic's Avatar
bismic
Nice help Tim
Old Apr 15, 2020 | 06:07 PM
HydroTek's Avatar
HydroTek
If you are calling the rear lower port -- the one behind the drive gear? - than that is the IPR blow off hole, air will come out that if the IPR is not energized
Hbarservices
Jan 11, 2018 01:02 AM
CampSpringsJohn
Sep 2, 2008 06:48 PM
captbrandon
Dec 8, 2007 06:44 PM
1968Mustang
Jan 31, 2007 06:14 PM
