Higher high-idle
Old Apr 14, 2020 | 07:01 PM
6.9IDIot's Avatar
6.9IDIot
Higher high-idle
I was just thinking about this when I started my truck today. When I put it into high idle there is an rpm increase and to a point it is noticable, but is there a way that I can increase the RPM's that the high idle runs at? It would just be nice for warming up on those extra cold days or running a hydraulic pump. I would be willing to make some modifications to have this feature.
Old Apr 14, 2020 | 07:21 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
just adjust the screw in the center of the solenoid.
Old Apr 14, 2020 | 07:28 PM
90Ford73's Avatar
90Ford73
You can adjust the high idle by unscrewing the rod that pops out of the solenoid and pushes against the throttle lever. Give it a turn n go from there. You should be able to jump battery positive to the solenoid terminal, that way you can fine tune right there under the hood n don’t have to wait for a cold engine.
Remember to manually push the throttle lever as the solenoid doesn’t have enough juice to push it, it just holds it. That’s why my solenoid burnt out, it was energized but nobody pushed the throttle to set it.
Old Apr 14, 2020 | 11:20 PM
DarkOverCast's Avatar
DarkOverCast
It's a 1/4" size, I have a little open end I use. I'm not sure how far it's adjustable out, but I've been able to get them to make it to idle at 1k
Old Apr 15, 2020 | 07:24 AM
RaymondIV's Avatar
RaymondIV
I put my cold fast idle system on a toggle switch years ago and unless the solenoids and mounting brackets vary a bit from engine to engine, the highest mine will set to is 900 RPM. Any more and I'm interfering with the normal idle adjustment screw.
Old Apr 15, 2020 | 01:57 PM
DarkOverCast
You can loosen the two 7/16" bolts a pivot that bracket to get a little more out of it.
One could also stick a 1/4" socket over the end and grind some excess of the square drive side.
Old Apr 15, 2020 | 01:58 PM
6.9IDIot's Avatar
6.9IDIot
Ok, I will try and see how far I can get it to idle up
Old Apr 16, 2020 | 06:55 AM
RaymondIV's Avatar
RaymondIV
It's been a while, but when I checked that out, it would interfere with the normal idle screw setting. The solution would be a solenoid with just a touch more travel in the rod. With the solenoid set to get over 900 RPM, it is pushing on the throttle lever when not activated and increasing normal idle speed.
Old Apr 16, 2020 | 01:42 PM
6.9IDIot's Avatar
6.9IDIot
Ok, I am going to go adjust it here in a few hours. Also I'm assuming the process to put it on a manual switch is to find the ground and hot wires and rig it onto a switch...?
Old Apr 16, 2020 | 03:26 PM
90Ford73's Avatar
90Ford73
It would be easier to run new ground and power wires to it than to cut or splice into the factory harness, especially when everything is relatively close together.
Old Apr 16, 2020 | 03:54 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the solenoid is already Grounded, you just apply power to it... mine kicks up to 1200 for the AC Compressor .... a Brass Schader valve cap fits fine for additional shimming.
Old Apr 20, 2020 | 01:45 PM
6.9IDIot's Avatar
6.9IDIot
So to go about this I would take a toggle switch and put power and ground to that so that it lights up like all the fancy switches do and then just grab the hot wire off that and splice right into the hot wire on the solenoid. Oh and I tested it and it in fact does bump up the idle quite a bit, way more than expected. I want to switch it I determined because with an automatic transmission, it's a bit sketchy running those higher rpms and the truck shudders because the TC is trying to lock up while the truck is stopped but in gear..... don't ask.......
akorcovelos
Nov 3, 2010 10:30 AM
jlo84truck
Jan 23, 2010 06:54 PM
07350PSD
6.4L Power Stroke Diesel
Feb 10, 2009 07:01 PM
Golflug
25
Feb 11, 2008 09:38 PM
Mike F250
Mar 17, 2007 09:22 AM
