Comparable later model suspension
Old Apr 14, 2020 | 04:23 AM
Aouli's Avatar
Aouli
Hi, Does anyone here know if any later model 4x4s that have comparable parts to my 62 f100 4x4? Leaf springs, shackles, spring hanger, etc. I wanna put a lift on my truck but no kits are available
Old Apr 14, 2020 | 09:28 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, 1963 and 1964 are both comparable. 1965/66 are different with a slipper leaf spring arrangement. Then anything newer is workable, and can get you disc brakes and a high pinion differential which will require a lift for clearance.
Try this thread for the details on installing a high-pinion diff.
https://www.ford-trucks.com/forums/1...ld-thread.html
Another less expensive option would be to get the leaf springs designed for your truck and have them arched a bit extra if wanted. Your leaf springs have probably sagged to where they have very little arch left as most do after 50+ years.
Old Apr 14, 2020 | 11:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1959/65 F100 4WD has leaf spring front suspension // 1966/76 F100 4WD has coil spring front suspension.
Old Apr 14, 2020 | 04:52 PM
User 71024's Avatar
User 71024
Up to '79 F150 has the same coil front setup also
Old Apr 14, 2020 | 05:13 PM
NumberDummy
Originally Posted by EricJ
Up to '79 F150 4WD has the same coil front setup also.
Yes, but 1976 was the last year for F100 4WD's. F150's were introduced in 1975.
Old Apr 14, 2020 | 05:31 PM
FordsOnlyGarage's Avatar
FordsOnlyGarage
Off topic trivia - I seem to recall the slang for F150 in mid-70's being "Heavy Half-ton"
Old Apr 15, 2020 | 02:43 AM
Aouli's Avatar
Aouli
Thanks for the info. I appreciate it
Old Apr 15, 2020 | 03:03 AM
Aouli's Avatar
Aouli
Really? Leaf springs can be made to fit on the original spring hangers and shackles?
Old Apr 15, 2020 | 03:06 AM
Aouli's Avatar
Aouli
Leaf springs
really? I can have them made to fit on my existing spring hangers and shackles?
Old Apr 15, 2020 | 04:24 AM
User 71024's Avatar
User 71024
Actually a GOOD spring shop will more than likely have an over the counter spring that will work, and if they don't can definately make you a set. Just keep in mind if you go too much over stock height you may need to change your steering linkage and you will need to align.
Eric
Tristian Knutson
Sep 4, 2017 05:22 PM
fordbubba8206
Offroad & 4x4
19
Aug 2, 2005 12:04 AM
Zinfinity
Sep 3, 2004 08:16 PM
airharley
Oct 3, 2003 07:52 AM
