Highboy speedometer cable length?
Old Apr 14, 2020 | 07:30 PM
lafermedavid's Avatar
lafermedavid
@NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by lostinfords View Post
Bill...what is the difference between an auto and a manual trans speedo cable?...gear/mounting/????
Parts catalog doesn't say one way or t'other, so I dunno.
Here's all the 1973/77 F250 4WD (High Boy) speedometer cables:
AUTOMATIC TRANSMISSION
D3TZ17260A .. Speedometer Cable ~ 105 3/8" long / Obsolete
Fits: 1973 F250 4WD.
No Ford Dealer or obsolete parts vendor has any.
D4TZ17260N .. Speedometer Cable ~ 118 1/4" long / Obsolete
Fits: 1974/77 F250 4WD. See post # 5 for the sources.
MANUAL TRANSMISSION
D3TZ17260A .. Speedometer Cable 105 3/8" long / Obsolete
Fits: 1973 F250 4WD before serial number S00,001.
D4TZ17260C .. Speedometer Cable ~ 107 5/16" long / Obsolete
Fits: 1973 F250 4WD from serial number S00,001 and 1974/77 F250 4WD.
Do y'all have the original speedometer cable? If so...you may not need a new one
Inside the speedometer cable's housing is a woven steel core. It's supposed to be greased every so often, but ppl do not know that.
When the woven steel core's grease dries out, it binds up inside the housing and SNAPS.
Autoparts stores sell a "universal" replacement woven steel core.
You cut it to the correct length, coat it with a thin film of white lithium grease and install it in the housing.
__________________
Bill / Retired Ford Parts Manager / SoCal Chapter Member / Part number research: 1928/89 FoMoCo vehicles.
2017 Fusion SE
Old Apr 14, 2020 | 07:49 PM
fordguy2100's Avatar
fordguy2100
Im going to need to look at mine some more too. Plastic gear in the t/c looks to be in good shape, the gear is in good shape, the core is in good shape. I spun the gear and watched the speedo rise. Never dropped off. Might be a bad spot on the plastic in the t/c but if so its not visible to me. I still need to go through my t/c so I will probably wait until then.
Old Apr 14, 2020 | 07:58 PM
Highboy46's Avatar
Highboy46
Mine on the inside was worse... huge chunks missing out of the gears. It was a mess. You should be able to chock the truck, pull the drive shaft and turn it by hand and see if there are chunks missing.
Old Apr 15, 2020 | 02:38 AM
NumberDummy's Avatar
NumberDummy
Originally Posted by lafermedavid
My cable is original to the manual trans /TC,short of nine foot by 3/4 of an inch plus my DRIVEN gear tooth is 19 D4TZ-17260-C
D4TZ-17260-C .. M/T Speedometer Cable - Use with New Process 435 4 Speed - 107 5/16" long / Obsolete
1973 F250 4WD from serial number S00,001 // 1974/79 F250 4WD
gostephen
Mar 1, 2018 07:39 PM
rsh1966
Feb 17, 2018 12:30 PM
69WestCoastFord
Jun 30, 2009 07:40 PM
Bookman
15
Feb 23, 2008 05:53 PM
beerinside
Sep 25, 2004 12:24 AM
