Speedometer cable is bouncing under 25mph
Old Jun 27, 2009 | 11:51 PM
69WestCoastFord's Avatar
69WestCoastFord
I just recently installed a universal speedometer cable and it bounces under 25mph. Anybody know how to fix this ?
Old Jun 28, 2009 | 04:33 AM
daddy172005's Avatar
daddy172005
Dont have an answer for you but do you really need it under 25?
Old Jun 30, 2009 | 07:40 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Lube up the cable really well before you install it in the housing. You can lube it up with Ford Speedometer Cable Lubricant, or white lithium grease will work.
Failing that, are the drive gear, or Cable gear damaged, or worn? That will also cause a bounce.
