Hinge pin puller
Old Apr 13, 2020 | 10:15 AM
Mixer man's Avatar
Mixer man
Exclamation Hinge pin puller
Has anyone tried this? Does it actually work?
https://www.dennis-carpenter.com/en/...nge-pin-puller
Old Apr 13, 2020 | 10:25 AM
blsd49's Avatar
blsd49
I have a broken one somewhere in the shop! The turn screw is very tight to the door when in place and not strong enough to move the pin. May work on some vehicles but not these trucks, imho.
Old Apr 13, 2020 | 10:43 AM
tip49's Avatar
tip49
Originally Posted by Mixer man
Has anyone tried ?
I too tried this years back but too light for the task.
Old Apr 13, 2020 | 10:51 AM
51fred's Avatar
51fred
As the others said, too light for the task and the hinge is too close to the body to get a good go at it. I have one here somewhere if you want to try.
Old Apr 13, 2020 | 12:23 PM
Mixer man's Avatar
Mixer man
Thanks for the offer but it looks like I'll pass on it after seeing the responses.
Old Apr 13, 2020 | 03:45 PM
electricmaniac's Avatar
electricmaniac
Those selling this for our trucks should know better. Instead, they either take of for fools or are fools with regard to this tool.
Anyone here want to tell us how wonderful this worked? How the pin came right out?
If so, I take it all back.
Old Apr 13, 2020 | 06:42 PM
CharlieLed's Avatar
CharlieLed
I bought one from Bob Drake to use on my 40 Ford coupe, so far it works good but then again the pins were out of the hinges when I bought the car so there wasn't a lot of friction to overcome. Works good to re-install the pins, less chance of hitting the door with a hammer.
Old Apr 13, 2020 | 08:16 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I've never tried one. I thought about it but then after seeing similar comments from the various members on this board I decided to pass.
I tried a hammer, just because you have to. Then ground the top of the pin flat, center punched it and carefully drilled the pin, starting small and working up until I could get the edges of the pin as thin as I dared. After that it was fairly easy to knock it loose with a hammer and punch.
The top part of the pins are slightly thicker and knurled a bit to hold them in place so thats all you have to drill out.
A little bit of patience and they'll come out fairly easy
Good luck
Bobby
Auger Hekla
Aug 19, 2017 02:58 PM
Usmc6.0
May 31, 2017 01:22 PM
pappy19
Appearance & Dress-Up
May 18, 2010 10:27 PM
delaney
Nov 27, 2006 04:01 PM
sancochojoe
Apr 1, 2004 06:47 PM
