Hpop is dry!
Old Apr 12, 2020 | 09:31 AM
Listor's Avatar
Listor
Hpop is dry!
After sitting all night , i checked the Hpop reservior , no oil in it, guess this is why i takes so long to crank, it has gotten worse over the last week , so i better get to rebuilding the hpop and ipr! Was hoping it would hold off till i had time LOL
Old Apr 12, 2020 | 10:43 AM
pvdiag's Avatar
pvdiag
I dealt with this problem for awhile. The work around is pretty easy - pour some oil into the rez and it should start and go. Problem is that you could overfill your pan if you do this too many times without draining some. I think my problem was a tired LPOP that couldn't refill a drained rez. But it would keep enough oil flowing so that it ran ok once I got it started. Replaced LPOP (and HPOP) and haven't had to refill since. Changing the HPOP wasn't a measure to solve the reservoir problem. At the end of the day, the new low pressure pump can stay ahead of the draining reservoir better than the old one. I didn't do anything to address the draining - unless somehow the HPOP plays a role, which I don't think it does.
Old Apr 12, 2020 | 11:00 AM
Listor's Avatar
Listor
I was wondering if the ipr had anything to do with it, need to look at how the system works , Sous had a link the other day that i will be working through
https://www.ford-trucks.com/forums/1...diy-style.html
Old Apr 12, 2020 | 04:20 PM
Walleye Hunter's Avatar
Walleye Hunter
I don't know if the IPR would do that or not but there is a check ball in the top of the block right behind the HPOP reservoir that's held in with a 3/8" plug. That will let your oil drain out of the HPOP reservoir if it's not working right. It's rare but it could happen.
Old Apr 12, 2020 | 06:01 PM
timmyboy76's Avatar
timmyboy76
Yup...but not behind, per say...more at 5o clock position to the hoop...
Old Apr 13, 2020 | 06:45 AM
Listor's Avatar
Listor
OK you got my attention, i am planning rebuilding the hpop anyhow, Just need some time ! working for a living takes up all my free time!
michaeld563
Jun 10, 2017 05:58 PM
JOBPSD1963
Jul 28, 2014 06:40 AM
John7894
Jan 3, 2010 07:56 PM
2 stroke man
Dec 21, 2007 10:10 PM
nesloe1
19
Feb 28, 2007 05:08 PM
