Radio
Old Apr 11, 2020 | 03:47 PM
Ross Johnson's Avatar
Ross Johnson
Radio
The radio doesn’t have any power going to it. Was working this morning. Turned it off and back on still no power . Checked the fuse on the back of the radio. Checked the fuse on the fuse panel and still good any suggestions
Old Apr 11, 2020 | 03:59 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Welcome to FTE!
Factory radio, check if the fuse on back of radio has 12 vdc when key is turned to Acc, or On,
Old Apr 12, 2020 | 12:42 PM
puppyf250's Avatar
puppyf250
Any reason not to upgrade to a newer stereo at this point? In my 94, and 91 I put in a Sony and a Kenwood single DIN. Used aftermarket wiring harness and install kit. Quick, easy, now have bluetooth, streaming music, all the goodies for a few hours of work.
Old Apr 12, 2020 | 01:09 PM
crashtestdummy's Avatar
crashtestdummy
I agree with puppyf250. I put in a pioneer single din with a USB port and built a custom amp for sound clarity and not for volume although I have 100 watts per channel not 100 x 4
= 25 watts per channel but 400 watts total. With a thumb drive I have over 40 hours of music to listen to with out hearing the same song twice.
Old Apr 12, 2020 | 01:54 PM
matt167's Avatar
matt167
My '95 F250, I liked the fact that it still has the AM/FM factory only radio ( F250 XL: ). I actually bought a $10 MP3/ bluetooth transmitter that lights up green, and that's all I use. Spent a little extra on the transmitter so it lit up green to match the dash lol.
Old Apr 13, 2020 | 08:21 PM
nekkidhillbilly's Avatar
nekkidhillbilly
you can mod a oem radio with bluetooth inside it if you are handy. plenty of yt videos. op so you will have a switched source and a constant source. check that you have 12 volts on one with key off check the other with key on. if those both work your radio has bit the dust. from there its someone that can solder and so forth.
WRCR
Jan 3, 2019 02:54 PM
T2 HUFF
1978 - 1996 Big Bronco
Feb 2, 2014 01:03 AM
The Blue mule
Jan 13, 2013 05:39 PM
VodkaMan
Dec 11, 2007 08:27 PM
mountainman101
Jan 21, 2005 10:11 AM
