Parts Compatabilty
Old Apr 11, 2020 | 03:26 PM
JimiT's Avatar
JimiT
Parts Compatabilty
Can anyone tell me if Fseries parts for 1964 are the same for 100, 250 350 etc. Many websites dont list the 350 which is what I have. I heard the body is all the same. Most parts I'm looking for are for the body.
Old Apr 11, 2020 | 04:53 PM
65navyf100's Avatar
65navyf100
You might want to use the search function on this forum to look for the specific parts to see if they'll work on your application. Number Dummy has posted about a million parts on here for various questions and he typically states their compatibility. Just a random example below:
Ford/Saginaw P/S gearbox is from a 1977/79 F100/250 2WD // 1977/78 F350 // 1979 F350 2WD
Good luck.
Old Apr 11, 2020 | 05:02 PM
62SY4's Avatar
62SY4
Mostly the same. Couple really obviously ones: front fenders have the bigger opening on the 350, the gravel pan is different (under grille), and battery tray 100/250 2wd is under the hood, 350 under passenger floor.
You are better off asking specifics, or buy a Fomoco parts book or cd.
Old Apr 11, 2020 | 06:03 PM
85e150's Avatar
85e150
FWIW, and IMO a bargain at twice the price:
https://www.hipoparts.com/1964-72-fo...ts-catalog-cd/
Old Apr 13, 2020 | 03:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ask for the specific parts you need. .
Old Apr 15, 2020 | 09:51 PM
JimiT's Avatar
JimiT
I am looking at Weather stripping (window anti rattle), windshield and rear window seals as well as door seals,
https://www.lmctruck.com/1957-72-for...and-components
https://www.lmctruck.com/1957-72-for...dow-components
Also the rear cab corner, https://www.lmctruck.com/1957-72-for...eel-body-parts
Old Apr 16, 2020 | 02:58 AM
NumberDummy
1957/60 F100/1100 is the same // 1961/66 F100/1100, 1963/69 N/NT500/1100, 1967/69 F800/1000 is the same.
1967/72 F100/750 is the same // But the thing is, the repro parts sellers only list the weatherstrips for F100/250 and in some cases add F350.
Old May 16, 2020 | 02:28 PM
racenitro's Avatar
racenitro
I have a 64 F-100 and a 62 F-250. The front fenders are different with the 250 having a larger opening. Interesting since Dennis Carpenter and NPD both indicate that the fenders for the F-100 and the F-250 are the same. Both trucks have original fenders.
These came in handy for my Combination of a 61 F-500 cab Front fenders from the 62 F-250 5.9 Cummins 12 Valve into a 95 F-350 extended cab dually frame.
Started with the F-100 fenders and stopped due to not enough opening. When a friend pointed out that the fenders were different I tried them and now everything fits perfectly.
Made new engine mounts and cab mounts and all fits and sits great....
Other things that are different is in 1964 the top of the cab was changed. Cab mounts changed in 1965 Fender inner panels also changed over the years.
F-100 and F-250 have same frame and same front axle including spindles. Just changed the hubs.
Old May 17, 2020 | 09:02 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The larger opening front fenders came on various trucks depending on if they got the larger wheels from the factory or if they were 4x4 or F350. So Dennis Carpenter and NPD are not wrong. The smaller opening fenders came on most F100/250 2WD trucks. 1962 is very similar with the 17.5 and 19.5 inch wheels getting the larger opening. So, it has less to do with 100/250 Series of truck than it does about wheel size.
richlars
May 12, 2017 06:17 PM
jrock99
Dec 10, 2008 06:14 PM
Karl Keicher
Aftermarket Products
May 5, 2008 11:54 AM
novadragman2005
Feb 3, 2005 08:37 AM
