Flathead V8 Timing
Old Apr 11, 2020 | 12:15 PM
mefordf1's Avatar
mefordf1
Flathead V8 Timing
I would like to know the timing on a flat head V8 1951 thats been bored 40,000ths over with a mile cam. Truck turns over real slow when warm like it has a dead battery. Starter is in excellent condition and has a 6 volt optima battery. All the grounds are good. Any suggestions?
Old Apr 14, 2020 | 07:14 PM
Beechkid's Avatar
Beechkid
advance the timing...… the bore has little to do with this...the cam grind..everything...with that said, you're likely going to have to set it by ear or with a vacuum gauge to what your engine likes... if you advance it too far, it will cough up through the carb especially when trying to start....this is going to be a "play with it until it feels good"
Old Apr 15, 2020 | 08:03 AM
mefordf1's Avatar
mefordf1
Thank you. Distrubuter cant turn any farther . vacuum advance hits block. Don)t know if I can reposition or move a tooth? Thanks.
rlandrum1953
Aug 26, 2015 10:50 AM
jeffie_3
Nov 17, 2013 01:22 PM
justanother1
Mar 30, 2007 11:05 AM
pilot815
1978 - 1996 Big Bronco
Sep 1, 2004 05:39 PM
AirSmitty
Electrical Systems/Wiring
Jun 13, 2004 09:40 PM
