1978 - 1996 Big Bronco
Timing
Old Aug 30, 2004 | 06:18 PM
pilot815's Avatar
pilot815
Timing
are there any special procedures i need to follow in order to set the timing on my 1988 bronco with a 5.8L.
Old Aug 31, 2004 | 09:35 AM
Kemicalburns's Avatar
Kemicalburns
have engine warm, remove spout connector and set timing with a light. have battery disconnected during this as well. then once you get it set should be at 10*-12* btdc reconnect every thing and go for a drive.
late
Old Aug 31, 2004 | 06:05 PM
pilot815's Avatar
pilot815
are you sure about disonnecting the battery?
Old Sep 1, 2004 | 08:50 AM
Kemicalburns
well, what i meant by that is it should be done after the timing is set that way the computer can relearn. i got a bit twisted there , my bad. so set the timing then disconnect the battery for 5mins then reconnect and drive it for 30mins in various conditions like stop and go traffic, some WOT that sort of thing.
thanks for catchen that
Old Sep 1, 2004 | 05:39 PM
pilot815's Avatar
pilot815
thanks for clarifying that
