Stuck Glow Plug (#7)
Old May 23, 2020 | 07:47 PM
  #31
djed's Avatar
djed
Originally Posted by BBslider001
How's your idle after the shim job? I am curious.
now 750. I think it’s up a bit but I don’t know for sure. I’m guessing it was 600-650.
Old May 23, 2020 | 08:01 PM
  #32
FordTruckNoob's Avatar
FordTruckNoob
Thanks for closing the loop on this djed. I'm glad things worked out for you.
Old Aug 15, 2022 | 04:15 PM
  #33
djed's Avatar
djed
I'm reviving an old thread to ask a question.
If I can't get glow plug #7 out of the hole, how can I purge fluid from cylinder 7 if I need to change injectors? I have a MightyVac somewhere in the garage as well as an oil extractor that requires shop air (not sure I have enough air hose to reach the street where the truck is parked).
In re-reading the thread FordTruckNoob also makes reference to a glow plug removal tool which looks promising but scary. Has anyone here used that tool? If so, does it work some/most/almost all of the time?
Finally, before I spend a bunch of money on a tuner, injectors, a turbo rebuild/upgrade, up-pipes, etc I think I'd like to revisit a compression test. My last effort failed because my gauge didn't hold pressure (we think due to the lack of check valve). With my experience, I hope this effort will work this time.
David
Old Aug 15, 2022 | 04:35 PM
  #34
Walleye Hunter's Avatar
Walleye Hunter
I dread the thought of a stuck glow plug. Can you back it out of the threads so any fluids can get past?
Old Aug 16, 2022 | 08:50 AM
  #35
Kwikkordead's Avatar
Kwikkordead
For what it's worth, a 1/4 inch drive socket won't bind against the rocker arm when pulling the glow plugs.
Old Aug 26, 2022 | 06:09 AM
  #36
FordTruckNoob
In addition to giving better clearance, the 1/4" drive equipment is a little insurance against getting too ham-fisted and breaking the hex off the top of the glowplug. I recommend bringing the engine up to operating temperature then attempting to loosen the glowplug.
Old Aug 26, 2022 | 09:48 AM
  #37
Kwikkordead
Yeah, you don't need anything more than a 1/4 inch drive socket to get them to come out, anyway. And you're right. It will save on a potentially much larger job if thing's go sideways.
Old Aug 27, 2022 | 01:52 AM
  #38
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the question is what to do about fluid in the cylinder when the GP cannot come out, don't worry about it. Pull the injector and crank it over by hand to eject 90% of any fluid, follow up with suction from a rubber hose on a soap bottle pump to get the last bits.
100% leave that GP alone! If the problem is a swollen tip your efforts to remove it will break it off. Whole new level of hell to fix.
stoker1995
Apr 25, 2017 06:54 PM
mrsvegan
17
Oct 19, 2013 07:26 PM
97biostroke
Feb 8, 2009 01:51 PM
dyoungen
Oct 24, 2008 09:17 PM
alanscott
Aug 12, 2002 02:26 PM
