62 ford
Old Oct 15, 2003 | 07:05 PM
tracy1's Avatar
tracy1
62 ford
im looking for a wiring harness and ignition switch for a 62 ford and i think a 67 will fit it also. any suggestions?
Old Oct 15, 2003 | 07:07 PM
dbc's Avatar
dbc
Didn't '
67 have the double edged keys?
Old Oct 15, 2003 | 07:11 PM
tracy1's Avatar
tracy1
it should'nt matter, should it?
Old Oct 15, 2003 | 07:43 PM
dbc's Avatar
dbc
Plug on the back is different, diameter of the switch is larger.
Old Oct 15, 2003 | 07:51 PM
tracy1's Avatar
tracy1
any suggestions
Old Oct 15, 2003 | 08:15 PM
barry's Avatar
barry
Look for a ignition sw. ffrom 61 -64 Ford trucks or from a 61-64 Car. THey're the same. NOS part number is C3AZ 11572-A . There are NOS ones out there. Try www.partsvoice.com and use your zip code as a password. Then put the part number I listed in and it will give you anyone on thier list who has one in stock. Call the number listed and get a price from them. What section of the harness are you looking for?
Barry
Old Oct 15, 2003 | 08:21 PM
tracy1's Avatar
tracy1
thanks barry, i want from the front to the back. the whole thing. bed is 9 ft. long so it has to reach back there. ill try what you suggested. thanks again,
tracy
Old Oct 16, 2003 | 01:19 PM
barry's Avatar
barry
Ok, post what the engIne size is, and what amp generator you have. I'll get you the NOS numbers. The rear harness for the lights is C2TZ 14405-BZ. If you have a 9 ft. bed (flareside?) on it, most likely the truck was a special order and has a different DSO code on the tag. This rear harness was probably cut and extented to reach the back.
Barry
Old Oct 16, 2003 | 02:41 PM
tracy1's Avatar
tracy1
hey barry,the engine size is 6 cylender. all i know is its 12 volt, dont know amp. gen. i have. how do i find that out?its a flat bed, i made it myself.
thanks, tracy
Old Oct 16, 2003 | 06:06 PM
barry's Avatar
barry
You have to look at the tag that riveted to the generator. Most are hard to read, if at all. It might be stamped in it. Anyway, here's what I have for you.
Main harness is C1TZ 14401-M
Dash to engine is C1TF 14289-C
Headlamp harness is C2TZ 14290-A
Generator harness (30 amp) CiTB 14305-A
Dash panel to engine is C1TB 14398-CU (30 amp)
C3TZ 14398-AZ (40 amp)
I gave the rear harness in the previous post.
You may want to go with a "painless" wiring kit, I know it would be cheaper and faster to get and install. There's been some talk in the forum about them. Look in the archives for them.
Barry
Old Oct 16, 2003 | 06:12 PM
tracy1's Avatar
tracy1
barry, thanks ever so much for your info.it has saved me a huge amount of time. all this is for my hubby so from him and i , thanks a bunch,
tracy
akbash
6.2L V8
40
Mar 8, 2016 12:09 AM
KLEO1480
Mar 2, 2013 06:53 AM
Ford Big Rig
6.2L V8
Mar 20, 2011 07:44 PM
sawtooth
2009 - 2014 F150
18
Jun 4, 2009 06:12 AM
JByrd1173
Oct 28, 2004 10:49 PM
