Engine Hoist / Cherry Picker?
Old Apr 7, 2020 | 06:43 PM
Tim Hodgson's Avatar
Tim Hodgson
I am ready to pull the engine out of the van. On vans you are supposed to pull the entire front body off and pull the engine forward.
I don't know if I should pull it with the AR100 transmission attached or not.
I have no idea how heavy the engine or engine/transmission is. Is this 2 ton engine hoist up to the job?
https://www.harborfreight.com/2-ton-...ane-69514.html
Any other suggestions or comments?
Old Apr 7, 2020 | 06:52 PM
DieselDenny's Avatar
DieselDenny
Pull em separate. Safer and smarter.
Reason being is you can replace seals as you should regardless.
It will go alot better,
Denny
Old Apr 7, 2020 | 07:03 PM
ford390gashog's Avatar
ford390gashog
Call a local equipment rental, you will be surprised at how cheap a legitimate 4ton cherry picker is to rent. The Herc rental here charges 105.00 weekly for them and its a beast unlike the Chinese folding units
Old Apr 7, 2020 | 07:06 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You may find the thread linked below of some use.
https://www.ford-trucks.com/forums/1...side-down.html
Old Apr 7, 2020 | 07:46 PM
Walleye Hunter's Avatar
Walleye Hunter
I think I'd leave the tranny in it. It's not that hard to disconnect and having it attached won't make pulling it out any easier. I'm not sure what you mean when you say you need to pull the entire front body off, you don't need to remove the fenders.
mr78F150
Apr 24, 2015 11:20 PM
JTHill24
Aerostar
Aug 27, 2007 11:52 AM
