M5OD to C6 :)
Old Oct 15, 2003 | 05:35 PM
95_Ford XL's Avatar
95_Ford XL
M5OD to C6 :)
Im fixing to take the Mazda 5 speed out and put in a C6. What all will I have to change so it will work. Am I going to have to change the drive shaft or anything like that. Im going to put a rachet shifter on the floor. Is my gas milage going to change a whole lot, its going on a 95 300-6 and later onto a V8?
Thanks Mike
Old Oct 15, 2003 | 06:02 PM
andym's Avatar
andym
I don't know about what you'll have to change (crossmember and driveshafts spring to mind), but I know your mileage will take a steep dive south. The C6 has no overdrive so your RPM's will be a lot higher on the road.
Make sure you get a small block C6.
Old Oct 16, 2003 | 05:05 AM
pfogle's Avatar
pfogle
You're going from ~.73:1 final in the trans to a 1:1 final. So unless you have 2.73 gears in the rear your mileage is going to go from (just an example) ~16 to ~12-13, also you will need the CORRECT flex plate for the C6 and your engine.
junkyardjeff
Mar 25, 2015 07:52 PM
ssn2197
Aug 3, 2011 11:11 PM
Prplmnsterf150
Jun 3, 2005 08:16 AM
95_Ford XL
Oct 24, 2003 11:22 AM
MustangGT221
User Gallery & Picture Display
Aug 4, 2002 01:26 PM
