1994 Econoline 150 issues
Old Apr 6, 2020 | 09:18 PM
ArthurHarringron's Avatar
ArthurHarringron
The van's dash is lit up like a Christmas tree... check engine, ABS, flashing air bag light, o/d flashing...back up lights inoperable when in reverse but they do flash between the shift from reverse to park or neutral... KOEO codes 121 332 334 452 628
Replaced VSS and it's plug...still a 452 code...had to start somewhere
I guess I'm asking if the neutral safety switch malfunctioning could be a possible culprit or is the problem more than this shade tree can handle?
Btw...the van's engine purrs and seems strong... the transmission does want to downshift inappropriately
Bought a neutral safety switch but it's plug was upward instead of rear facing and the shift linkage hits the new part's plug...gonna try for a proper replacement tomorrow.
Any advice would be appreciated...thanks
Old Apr 7, 2020 | 09:18 PM
donjamer's Avatar
donjamer
Moved to Appropriate forum
martin78
Aug 6, 2025 05:00 PM
jmuenchow
Jun 1, 2018 03:45 PM
cray0971
Aug 25, 2011 08:46 AM
fmc400
Jun 1, 2005 01:39 AM
Wakeboarder141
1978 - 1996 Big Bronco
Nov 3, 2004 09:14 PM
