Intake port
Old Apr 5, 2020 | 09:50 PM
trap4x4's Avatar
trap4x4
Intake port
Can this , or should this be cleaned?
Old Apr 5, 2020 | 10:36 PM
440 sixpack's Avatar
440 sixpack
Not a typical look, maybe it the picture or has it been sitting a long time ?
Old Apr 6, 2020 | 12:21 AM
trap4x4's Avatar
trap4x4
Ya , just fired up after about 6 years. Just the #8 intake affected on a 460.
Old Apr 6, 2020 | 09:46 AM
440 sixpack
My concern would be more what the valve , seat and cylinder under it looks like. I assume it got some moisture in there
If it were me I'd just wipe it out and go with it , see what happens it might be fine.
Old Apr 6, 2020 | 10:06 AM
trap4x4's Avatar
trap4x4
Ya , obviously the coolant port leaked into the chamber. I misted the chamber with marvel and will blow it out. Was replacing the intake with a factory erg delete 4 bbl i have ....Did a compression test and that cylinder was below 90. Other than firing it up after transplant and header install , engine has been sitting for at least 6 years. Like you say... it may come around after run some more....Not keen on removing the head though. Its just a "rat rod" project at the moment. I do have 3 other D3VE heads on parts vehicles though.
Old Apr 6, 2020 | 10:15 AM
440 sixpack
If it was a leak and not just rain water that's better , the antifreeze helps a little.
you probably know but be sure to change the oil antifreeze is murder on bearings.
Old Apr 6, 2020 | 10:20 AM
trap4x4's Avatar
trap4x4
ya oil change will happen once back together. doesnt look like any coolant in oil. Valley pan had rust in that corner as well and seal seemed good when pulling old intake off.
Anthony Paul
46
Dec 21, 2019 04:44 AM
Anthony Paul
Dec 5, 2019 11:46 AM
defekticon
Ford Truck Parts for Sale
Jan 5, 2018 06:23 AM
Jocaren
May 28, 2014 04:03 PM
openexcess
May 30, 2011 09:21 PM
