07 Ford Edge electrical issues
Old Apr 5, 2020 | 05:20 PM
bigern6697's Avatar
bigern6697
Hello all
I have a 07 edge that sometimes does some wierd stuff. After I have driven the car and warmed it up, I turn to car off and hear a clicking coming from behind the gauge cluster and door locks wont even work. When yo go to restart the car it wont even make a sound and the a couple of tries later the car will fire up and act normal.
I have checked the battery voltage to be 12.5 volts and when started the alternator is working and putting out 14.4 volts. I haven't found any bad fuses. But it seems like it would be really strange for all these issues to be tied together, shy of a bad battery. I'm just not sure. I have tried searching with no success. Any ideas?
thanks in advance
Old Apr 5, 2020 | 09:03 PM
Franklin2's Avatar
Franklin2
Bad battery or a bad connection on one of the battery cables seems like something to check first. After you crank if over go out and feel for any warm feeling areas on the battery connectors and large wiring cables.
RV_Tech
Aug 1, 2016 05:35 AM
axledragger
Crossovers
Mar 28, 2016 06:14 PM
TexasBeachBum
Feb 6, 2014 04:06 PM
LACityFD
2004 - 2008 F150
Jan 5, 2009 04:55 PM
