Modular V10 (6.8l)
High Temp Problem
Old Apr 4, 2020 | 10:01 AM
ScotF150's Avatar
ScotF150
High Temp Problem
2004 Excursion, 6.8L w/215k miles running OE cooling system. Driving down the interstate yesterday @ 75 mph and gauges indicated an over temp condition. Engine went into limp mode, AC compressor went off, CEL came on and dash temp gauge pegged out hot. I pulled over, shut down and checked the engine compartment. Belt and hoses were good, coolant level was good and not boiling over. Everything appeared normal so I started it back up and headed out. I kept the speed under 70 and the coolant gauge was normal but as soon as I run it up above 70 the gauge started bouncing around and then pegged hot. I slowed back to under 70 and gauge returned to normal. I cruised on back home for almost 2 hours @ 70 mph without any issues. I suspect the temp sensor is the problem and will change it first. I have about 60k on the coolant and thermostat and will change both while I’m at it. Any suggestions on other issues that would cause this? Thank you for any input.
Scott
Old Apr 5, 2020 | 05:36 AM
JWA's Avatar
JWA
I had a similar issue with a 5.4 in an E250---turned out to be the radiator, about 264K miles at the time. I too went through the entire system, did find a leaking under pressure degas bottle however that was easily spotted from the tiny geyser.
There were no leaks, no water/oil mixing and the transmission fluid also coolant free. I did a half-assed flow test with upper and lower radiator hoses disconnected running water from a garden hose---there seemed to be no restriction. I did replace the fan clutch and serpentine belt for grins but kept original water pump. Since that swap all has been good even on the hottest days with A/C running full time, speeds typically 70 MPH and I do not tow anything.
I hope this is only a sensor but would be good to check the radiator too
Old Apr 5, 2020 | 02:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
There have been reports over the years where the PCM thinks the engine is overtemp and goes into limp mode. This might count at around 5 or 6 times I heard of this over the years I've been in the V10 forum. It could be the CHT (cylinder head temperature) sensor, but it could also be the PCM itself not reading it correctly requiring a PCM replacement.
Get a Bluetooth OBD-II dongle, Torque app on Android, and read the actual temps the computer is "seeing".
Old Apr 7, 2020 | 07:39 AM
ScotF150's Avatar
ScotF150
Thanks for the replies! I’ve ordered the temp sensor and it should be here in a couple of days. I’ll get it replaced and see what happens. We want to keep the Ex a few more years so I’m going to rework the cooling system. After 16 years and 215k miles I think its time.
Scott
Old May 11, 2020 | 03:55 PM
ScotF150's Avatar
ScotF150
I replaced the radiator, t-stat, water pump, degas bottle, cap, fan & fan clutch, temp sensor, belt and hoses. The temp sensor fell apart as I was removing it and the fan clutch appeared to be weak but everything else was OK. Took a long drive on the interstate (after a few trips around town) and everything is working ok for now. I'll update in a few weeks.
Scott
Old May 11, 2020 | 05:41 PM
krewat's Avatar
krewat
Thanks for reporting back, Scott
Old May 13, 2020 | 05:25 AM
JWA's Avatar
JWA
Good news indeed---glad its sorted out now.
I myself think you did the right thing replacing what you did--at that mileage hard to know what might have been next to fail. I did much the same on my own E250 at about 263K miles, been trouble free for about 30K miles and a few years now.
Indeed thanks for the update!
Old Jun 6, 2020 | 07:38 PM
ScotF150's Avatar
ScotF150
6+ hour road trip on the interstate today with temps in the upper 80's and no issues at all. I think I got it fixed!
Scott
ScotF150
Jun 22, 2020 07:48 PM
wcwinans
16
Sep 5, 2019 09:04 AM
Deadsquiggles
1978 - 1996 Big Bronco
Sep 29, 2015 02:02 PM
hoss khaos
17
Jan 14, 2012 10:41 PM
jb1390
Sep 3, 2005 07:47 AM
