Sponsored by: Real Truck
wiring diagram
Old Apr 3, 2020 | 12:15 PM
Dave Puskar's Avatar
Dave Puskar
wiring diagram
hi, i traded my 2010 ford f-350 for a 2014 ford f-350. while hooking up the camper to the 7 pin on the hitch all i get are tail lights and backup lights. i'm wondering when they hooked up the camper to the old truck they wired it differently. i cannot find a diagram for my 7 pin and wire color for each pin. i looked online but see numerous pictures of the 7 pin, but they are all different. can someone show my a 7 pin picture of the connection that is for my 2014 ford f-350?? the wiring colors on the camper are different on the other connections. i dont know what to do first. if i use a tester and say the left pin shows yellow for the left turn signal on the truck and the camper shows brown for left turn signal and it's on the top right pin, how do i get it changed to be on the correct pin? as a lasr resort i'll have to take it to my rv dealer for them to fix it. thanks
Old Apr 5, 2020 | 11:19 AM
Grampinator's Avatar
Grampinator
Your truck connector should be wired per this diagram:
You can check it with a test light. Ideally your trailer/RV would match this (in mirror image). The colors should match pin to pin, but if they do not, the more important thing is that the pin functions match. I will ask this question gently (because I have done the same thing), are you sure you are not inserting the trailer connection upside down? There is a ridge on the trailer connector that goes into the groove on the truck connector. Even though it should not work, I did do that on my truck and travel trailer one time. Locked the trailer brakes up while traveling at speed and scare the c*** out of me. Also, some connectors allow you to unscrew the wire to each pin and attach a wire to the pin that you want. Usually aftermarket connectors. He is another image the shows truck and trailer connectors. These pinouts are "standard".
Old Apr 5, 2020 | 05:44 PM
Just Strokin's Avatar
Just Strokin
The 7 pin cover should have the pins identified on it. Look at the cover.
Old Apr 6, 2020 | 09:51 AM
cjssr's Avatar
cjssr
Are you hooking up a Lance Camper by any chance as they don't follow the normal color codes?
File Type: pdf
Last edited by cjssr; Apr 6, 2020 at 09:56 AM. Reason: adding lance wiring so available if needed
Thomasf3
May 29, 2024 11:48 PM
SEAL1
All Things Towing
Jun 24, 2015 09:59 AM
jwdenney2
2004 - 2008 F150
Jan 19, 2009 07:36 PM
Btravelen
Dec 28, 2006 11:02 PM
F350_Lance
Feb 9, 2005 07:51 PM
