F1 power steering??
Old Oct 15, 2003 | 03:12 PM
blatherskite's Avatar
blatherskite
F1 power steering??
Does the toyota PS box conversion only work on the 53-56 f100s?? I haven't seen any listed in catalogs for the F1s.
Is there another simple PS conversion for an F1 with stock steering/suspension??
Thanks for any info.....
Old Oct 16, 2003 | 09:05 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I haven't seen anything for the older trucks. You may have to change a little more than the steering box to get PS on your F-1...a Chrysler torsion bar suspension, perhaps? Besides, if you improve the steering, then improving the ride and handling can't be far behind, so why not bite the bullet and get it over with?
Old Oct 16, 2003 | 09:42 AM
Scott123's Avatar
Scott123
F1 power steering
There is a power-ram assist option you can do to put power steering on your F1. It is pricey, about $900 not including the pump. It replaces your drag link, pitman arm, and tie rod, and has a ram-cylinder that bolts to the axle and new heavy duty tie rod. It is expensive, but allows you to keep your whole suspension and steering box stock and you don't have to fabricate any brackets on your frame like the toyota swap needs. I had several catalogs that advertized it but found only a couple still stock/sell it, being sacramento vintage and classic performance.
P.S. As if the unit's price isn't enough, you have to be sure your stock steering box is in good shape, as any play in it will be "amplified" for lack of a better term. Buying a rebuilt box can be upwards of $500, I was lucky enough to just need a new worm gear and bearing/gasket kit so I rebuilt mine for around $130, including having the bushings replaced and worm gears changed on the shaft at a machine shop.
Old Oct 16, 2003 | 01:12 PM
4tl8ford's Avatar
4tl8ford
Both
F100 Connection and Bob's F100 have kits to install the Toyota Steering Box on the 48-52 F1, both power and non-power.
adcruise
Jan 6, 2014 05:59 PM
skeleton
23
Nov 13, 2010 05:32 PM
lefty rodan
May 1, 2010 01:25 PM
lizardman1
Feb 11, 2008 04:15 AM
HBINGER1
Nov 14, 2002 09:11 AM
