I'll be honest, I did not exhaust the search feature before asking the question......Does anyone know of a switchable fog light bulb that is Orange / White? Given different conditions I would like to be able to turn on an 'Orange' bulb with an up-fitter switch and utilize the 'White' with the typical fog light switch. No intention of running them at the same time, just one or the other.
If, there is another thread on this very topic, Im more than willing to spend the time sifting through the thread if one of knowledge could point me that direction.
I have the switchback bulbs from LASFIT. Initially worked great during the snow, switched to amber for the better vis and back to bright white for non snow driving. About 2 weeks after install the amber would come on and then one would go back to white. Every time....emailed them and they said there was several complaints with the same and they were working on it....FWIW...
This sounds like exactly what I was after, Thanks Maiden!!!
Thanks so much,
BF
Are you talking about switching your OEM fog light bulbs?
If so, do you have the OEM LED fog lights?
Yes, exactly. Guess i'm on the hunt for a 'switchable' bulb that can replace my factory Fog-Light bulb, setting #1 white, setting #2 orange. Or if there was a full replacement housing that looked similar to factory that could work too.
I dont believe mine are LED, standard Lariat package with standard headlights.
That might be a tricky one to find because I’ve never heard of a replacement bulb doing that and if something like this does exist, more than likely it’ll be some kind of replacement housing / fixture.
You might want to take a look at the Rigid quad fog light setup but be warned, their proud of them and the price reflects said pride.
Not sure about fitment but I did get a set of lights off Amazon a couple years ago that were amber/white. Hooked them to upfitter 1 and 2 so I could run them together or separately. They went on my winch mount so as I said not sure about fitment in the factory bumper but it might be worth looking into with some measurements of the space available.
