fuel return lines
Old Apr 1, 2020 | 07:37 PM
1960fordf350's Avatar
1960fordf350
fuel return lines
I'm getting ready to pull my fuel filter bowl and do a reseal on it. While out I want to do the HPOP lines and the rubber fuel lines going to the front of the heads. I see the HPOP lines all over EBAY, but where do I find the fuel lines? I'd like to replace them also. I see the drivers side connection at the head is a pleasure to get at. Can I unbolt the bracket for the compressor/power steering pump to get at it? Does this bracket corner around the block and have bolts not only in the front, but the side too? While I've got the can of worms open, I'm going to do injector O-rings also. 96 F250 powerstroke
Old Apr 1, 2020 | 09:45 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
We carry everything that you are looking for.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Apr 1, 2020 | 10:38 PM
Hit Man X's Avatar
Hit Man X
Smart move doing return lines from heads. I tell FNGs that all the time and they think I am crazy. Do Riffraff CCV to turbocharger boots while in there...and that Stancore glow plug relay. May as well do CCV orings too.
I have purchased a pile of stuff from Dieselorings. Great outfit.
Oh. My HPOP lines are from 'Crude Diesel' ran about a C-note shipped. 25k without issue. They are on ebay out of Florida.
Old Apr 1, 2020 | 11:45 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
We now offer upgraded stainless steel braided return lines.
https://www.riffraffdiesel.com/drive...el-line-94-97/
https://www.riffraffdiesel.com/passe...el-line-94-97/
Old Apr 2, 2020 | 11:58 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Originally Posted by Riffraff Performance
Awesome.
I am going to upgrade my rubber ones to those next time I mess with the fuel system. I bought my current set from you guys after my driver's side blew out on a 13hr trek!
Old Jun 1, 2020 | 01:35 PM
voodoosmooth's Avatar
voodoosmooth
Resurrecting this thread, how do you get to the driver side head port (under the air conditioning compressor)? Do I need to remove the compressor?
Old Jun 1, 2020 | 01:51 PM
Coralyns97's Avatar
Coralyns97
Remove serpentine belt from compressor. Remove the four bolts that hold the compressor down. Keep all lines to compressor attached and use rope or bungee to hold up the compressor. Locate the four bolts that hold the compressor/ps pump/vac pump bracket. I took the bolts out most of the way allowing me to pull the bracket out just enough Giving me access to fit a wrench on the fitting for the fuel line. Makes it easier to reassemble. Remove old line and attach new line, don’t over tighten.
Reassemble in reverse order.
Old Jun 1, 2020 | 02:29 PM
voodoosmooth
Thank you! That's what I was thinking but appreciate the confirmation.
Old Jun 1, 2020 | 05:26 PM
voodoosmooth
Now I have to order the passenger side. I ordered an OEM version from Diesel O-rings (I think) when I did my e-fuel setup. I am just going to do both of the RR Diesel lines. RR, expect another order....
PrescottIce
Aug 9, 2018 11:51 PM
Edward Michael
Feb 13, 2018 12:22 PM
nivrig
Apr 28, 2014 08:09 PM
CoachRobb
Jul 9, 2007 08:11 PM
salewit
Jun 26, 2006 10:52 AM
