Weird electrical
Old Apr 1, 2020 | 01:46 AM
David Hohn's Avatar
David Hohn
Weird electrical
I was bleeding my brakes today and noticed when holding brake pedal down my gas gauge went 1/4 ways past the full mark and dropped back down after releasing the pedal? Anyone else seen this?
Old Apr 1, 2020 | 07:51 AM
Tedster9's Avatar
Tedster9
Hi Dave
Check carefully first that the ground straps, at engine, frame and firewall aren't loose, missing, or corroded. Also that the gauge panel and anything in the dash has good ground. Electrical strangeness is always a result of stuff hunting for a good ground. If they are original especially or even just kinda old replace them. I bet if you were to test more accessories and turn signals etc there are other faults as well. Could be some defective socketry going on too, but it's something that needs fixed either way.
Old Apr 1, 2020 | 11:27 AM
David Hohn's Avatar
David Hohn
Thanks for the tip I will search for grounding issues.
Old Apr 1, 2020 | 12:20 PM
torq'ta 5 8's Avatar
torq'ta 5 8
this tells how to test positives/grounds
Classic Broncos .com - Tech: Basic Vehicle Electrical Diagnosis for 66-77 Early Ford Bronco
Old Apr 1, 2020 | 10:02 PM
David Hohn's Avatar
David Hohn
Originally Posted by torq'ta 5 8
thank you i will check it out tomorrow had to replace harmonic balance today on her. Big difference.
Old Apr 1, 2020 | 11:28 PM
1TonBasecamp's Avatar
1TonBasecamp
And even though it might be a long shot (unless you have dual exhaust?) you might just run your hand along the wiring loom on the driver's side frame rail, or wherever your main bundle runs to the back.
If you have some kinked, burned, cut or otherwise compromised wires in the back you might simply have a small short-circuit going on.
I agree with all the grounding suggestions. Weirdness is almost always a ground issue. But when you hit the brakes, the brake lights come on whether the key is ON or OFF, and at some point a brake light wire is probably very close to the fuel sender wire(s).
Do you have dual tanks, or a single? If duals, which position is the switch in, and if you flip the switch does the madness with the gauge still happen?
Paul
Old Apr 20, 2020 | 04:35 PM
David Hohn's Avatar
David Hohn
Thanks to all who have responed. Two tanks and yes it happens no matter which position the selector switch is in front or rear. PO Installed electric brake controller(the job looks clean) and when I push the activate button with or with out trailer hooked up,gas guage gos up..no other gauges seem to be affected. Unplug sellector switch gauge dosnt move when brakes are apliad or trailer brake switch is pushed,keep switch unplugged,turn on ignition fuel gauge gos way past full.
thrasher141
Aug 24, 2023 08:24 PM
Brown Falcon
Aug 7, 2009 09:10 AM
truestory
Dec 31, 2005 12:50 PM
Cheapevil
Dec 23, 2004 10:46 PM
