Rear ABS
Old Mar 31, 2020 | 09:19 PM
Tom D's Avatar
Tom D
Rear ABS
My Rear ABS indicator light flashes 16 times when I turn on my ignition key. Would someone please tell me what my problem is?
Thanks
Tom
Old Mar 31, 2020 | 09:43 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
trouble code 16 generally means system OK
IF the KAM fuse is blown this is what you will see...
Old Mar 31, 2020 | 09:45 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
KAM = Keep Alive Memory
Check fuse #17 and Fuse #4 also check fuse #18
Old Apr 1, 2020 | 07:43 AM
Tom D's Avatar
Tom D
Thank you lonewolf. I will check that out and get back with you
Tom
Old Apr 1, 2020 | 09:53 AM
Tom D's Avatar
Tom D
I pulled each fuse by removing and checking for continuity. (Dash fuse block)
They all tested good. Now what?
Hope this doesn't end up like the wiper motor/ PCM you helped me solve
Thanks for your help AGAIN
Old Apr 1, 2020 | 10:10 AM
Tom D's Avatar
Tom D
I FOUND PROBLEM. The 7 pin trailer plug is corroded. 2 wires touched and one is hot with key on. It back fed the ABS.
Thanks for your help. lonewolf
Old Apr 1, 2020 | 07:47 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ahhh good deal, Trailer Brake control pin most likely as that wire goes right to the RABS controller
Great Job
Old Apr 3, 2020 | 10:36 AM
Tom D's Avatar
Tom D
Well.. I thought I had the problem solved. The RABS light would not flash as long as I didn't hit the brakes so I thought I was done. As soon as I hit the brakes, it started to flash again. It flashes 15 times and the 16th is steady until it recycles again and starts to flash.
Do you think this is similar to the indicator that needs to be centered between rear and front brakes to keep from appearing on the dash? Before all this started, if I held my foot on the brake, the other brake indicator would appear steady which told me I had to bleed the front or rear to "center" the sensor. Never got around to it.
Old Apr 3, 2020 | 01:38 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Bummer.... but Ok .... Bleeding the Brakes and making sure you have no leaks is the first thing to do.
I sent you a PM with link to my Guide on RABS
Old Apr 3, 2020 | 02:03 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
pretty sure you don't have a wiring issue in this case ..... pulling codes from RABS is done with a jumper located behind the glove box on the 93... what you are actually seeing is just Fault on the dash but not actual CODE.
hopefully you won't have to dig into the electrical for this one, but I'll be here to help God willing and the Crick don't rise
Old Apr 8, 2020 | 01:24 PM
Tom D's Avatar
Tom D
Thanks very much for the RABS file.
THe latest observation is that it seems to be clear until I plug in my trailer. So now I'm T-shooting that.I
I'll let you know
Old Apr 16, 2020 | 04:34 PM
Tom D's Avatar
Tom D
I'll let you know
ok lonewolf. The problem was initially the two contacts in my truck end of the plug. After fixing that, the problem transferred to my trailer. Finally all is well. Thank you for your help.
Tom
Old Apr 18, 2020 | 04:19 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Fantastic
'04 PWRSTROKE
Dec 25, 2007 08:46 PM
Andy_H
Nov 24, 2004 08:58 PM
elspode
Dec 24, 2003 06:45 AM
aroundtown
Sep 20, 2003 02:42 PM
peter matthews
Jul 15, 2003 11:17 PM
