abs
Old Sep 19, 2003 | 11:12 PM
aroundtown's Avatar
aroundtown
abs
I am getting the ABS yellow light after I start moving. It stays on until I turn the key off.
Old Sep 19, 2003 | 11:24 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
abs
You are going to have to put a scan tool on it to determine what the malfunction is.
When the ABS light is on the system has shut itself off, the good news is the normal power assisted braking system is unaffected.
Old Sep 20, 2003 | 02:42 PM
dozer384's Avatar
dozer384
abs
i had the same problem with my truck. i checked the abs sensors; two in the front and one on the rear axle for continunity, with an ohm meter. i found the rear sensor to have no continuity, bought a new sensor at dealer for $18 installed it and light stayed out.
good luck
