Wrong hubcaps?
Might the colorscheme be the same as the background for the fordlogo on the tailgate?
Sorry for beeing slow on answers. Have ordered a rubber mallet. The ones I found locally were to small/light/cheapbuilt.
Also, it’s caos at work at the same time.
Got plates mounted yesterday. Had to order them, since the goverment has closed the controlstations doing the service of legal matters, such as plates.
Be safe out there everyone
Thanks Josep. Looks to me that we have the same, original rims. That’s why it’s such a mystery to me with the hubcaps. Such a small, simple thing, but hoping a rubber mallet will be the answer
Your bumper which I can't remember the name of the manufacturer, was very common in the 60;s and early 70's and it was more of a standard silver. to be correct it was almost corny looking a little too bright in my opinion. something like Eastwood's wheel argent would be very close. but on the wheels it's not dark enough in my opinion.
Technically we're looking at two different bumper silver's and a wheel silver here. not a matter of life or death but it's important to me because I grew up with these pickups and I know what's wrong when I see it and it bugs me. one thing I will say is I wouldn't paint the bumper and the wheels the same silver. they never were and it will look like someone didn't try.
But if you like the white you could keep that on your wheels, we never owned one with white wheels until 1978 but you see a lot of earlier models with them. I don't know if it was original but I bet nobody over there can argue it isn't.
Wheel with cap
Wheel without cap
Inside of cap
Tools used for removal & installation
Wheel with cap
On my wheels there are two hub cap retaining nubs which are a bit larger than the other two. They are opposite each other. The other two smaller ones appear to be more for alignment than for retaining the cap. Be sure that the larger two are not damaged and that there is not an excess of paint behind them. Also be sure that the inside diameters of the caps are not distorted. I usually install mine by just hitting it with my hand after "hooking" the cap on one of the larger nubs. So far none of them have ever fallen off. The rubber hammer is used only when the cap will not easily go on by just hitting it with my hand.
Be aware that the OP probably does not have this hubcap, because there's another that looks exactly the same and is the same 11 3/4" diameter.
The OP is having difficulty getting his caps to fit and stay on, so it's probably C7TZ-1130-B .. It looks the same, but the depth is shallower.
His hubcaps are hitting the hub, why they're hard to put on...and keep on.
I do recall all the hub caps we had fit any pickup I put them on , all were split rims. but I know from research Bill is correct there was a deeper cap, whether it was for a different rear axle or a different wheel I don't know.
I do know I have a set of 1130-B's on a '74 high boy now with aftermarket 16x8 wheels and they fit fine. so I don't see why the OP should have any issues.
Those of you writing tips for ”how to”. Belive me, I’ve tried it all. Used a fine file and sandpaper to make one of the ”humps” on rim a tiny bit smaller. Aware of not taking to much, ruining the connection. Didnt make anything better...Used a rubber mallet. Compared and messured front with back ones(already mounted when I bought the truck).
Thinking the problem is what number dummy is saying about the two similar but small difference in depth.
Gonna look it up when I get it back. Mechanic was familiar with the model of both truck and carb. We agreed that if using to much time on repair or faultysearch, he would just mount a manual choke or go for a new carb. Fine by me
I'm wondering if you don't have wheels of a Dodge or Chevy or something. although I would still think the caps would fit.
Do they fit the front okay ?
Fit? Are talking about the caps now? The problemarea IS the front. Bought the caps for the front. Back already had original caps mounted. When I look at other rims, your’e right. Mines are rounded off on the pattern around the open spaces, compared to Josep’s....might not be Ford ones?
Edit: Looked at Ozzie’s pics now and we have the exact same steel rims...(confused)...
You may have wheels off something else. but even at that most hub caps for 3/4 tons were 12' in the day. I can't say all caps would fit all wheels but most would. you may just have to take a die grinder and get after it a little harder.
