Transmission issues
Old Mar 31, 2020 | 02:12 PM
derek4343's Avatar
derek4343
Angry Transmission issues
Well my first thread was on the “ bump,bang” when accelerating from a rolling stop. I took the advice of another poster and got the correct grease and lubed up the shaft. After putting everything back together and yes I did mark the shaft so that it would go back where it was,I have developed a vibration.Now what?
Old Mar 31, 2020 | 09:51 PM
Blue4.6's Avatar
Blue4.6
2010 F150 Crew-cab 5.5ft bed
You know I did the same thing for the same issue and got the same result. Ending up with a u-joint that had little movement, tried changing it, made it worse. Replaced the throw away driveshaft with an aftermarket heavy duty solved that issue for a while. How did the u-joints and carrier bearing look?
Now Ive developed a new vibration but still investigating. I was leaning towards transmission, but regardless of engine speed and gear the vibration remains the same. I think something else is afoot with my truck. I am trying to determine, when, how, what speed(s), which gear, etc.
Old Apr 1, 2020 | 07:22 AM
derek4343's Avatar
derek4343
I suppose the joints seemed fine. But never had a vibration before doing all of this. Just aggravated that I have to do this all over again. I guess I’ll look in female section to see if there are any signs of where it was.
Old Apr 1, 2020 | 12:57 PM
derek4343's Avatar
derek4343
Well I disassembled everything again and this time I removed the front shat and greased it. In a TSB that I read it said to shift the carrier bearing as far rearward as possible, which I did. It wasn’t possible to put the spline in any other way except the way I had it originally marked on the first day. One thing that I read was to mark the original metal boot straps and reuse back in same position. I’m hoping that two straps missing isn’t what’s causing my vibration..after doing all this over again it still has the vibration at all speeds. Go figure. I guess I’ll wait to see if any has another solution. Thanks
Old Apr 1, 2020 | 02:19 PM
derek4343's Avatar
derek4343
Come to think of I can put the yoke into center bearing multiple ways and just spin the back tires to match where the mark is that I applied. At this point it would take a lot and long time to get this vibration out. Not sure I’m up to doing that 50 times.
timsexcursion
2009 - 2014 F150
Dec 20, 2015 01:33 PM
dieselsubmariner
26
Aug 17, 2013 09:15 PM
Firemudder
Oct 17, 2012 08:21 PM
CJK440
1997 - 2003 F150
Jan 10, 2005 07:56 AM
85 F-350CrewCab
Sep 12, 2004 11:00 PM
