cab to bed alignment issues
Old Mar 29, 2020 | 08:05 PM
Renner68's Avatar
Renner68
I have a73 f100 2wd short box, I am re assembling my truck and have about 3/4'' of misalignment between cab and bed. the bed needs to come up. I am assuming its from the new rubber cab mounts. do I shim up bed? Shave rubbers down? I assume they will compress over time but not 3/4". what say the experts
Old Mar 29, 2020 | 08:34 PM
440 sixpack's Avatar
440 sixpack
They used washers at the factory to set the bed. you can add more and remove them later if your mounts settle.
Old Mar 30, 2020 | 06:23 AM
Renner68's Avatar
Renner68
ok thanks I knew they aren't perfect from factory, will do that with some starboard.
Old Mar 30, 2020 | 08:27 AM
vtpkrat2's Avatar
vtpkrat2
3/4" of an inch sounds like a lot. My '76 Short box was also misaligned with the box being low. I made sure my new cab mounts were tightened (squished down) & made sure nothing was "hanging up" on anything,anywhere. My box was only a strong 1/4" down on 1 side & even on the other. Shimmed a couple of 1/8" to bring the rt. side up which in turn tipped the left side down a bit. An 1/8th over there and pretty darn good lines. Just saying; do a little more poking around before shimming a whole 3/4". Seems like something askew. gary
Old Mar 30, 2020 | 09:06 AM
440 sixpack
I agree 3/4 is a lot. normally it's within 1/4 " .
Old Mar 30, 2020 | 05:33 PM
Renner68's Avatar
Renner68
so I checked my cab mounts to make sure they were socked down, I got about three turns on each one. didn't help much. I made a couple 1/4'' shims as there really is not enough threads even for a 1/2" shim. the 1/4" is not enough so tomorrow I will go 3/8" and settle with where ever that leaves me. I did find some old pics from before the tear down and it was fairly low. thanks for responses.
cooljman1
1997 - 2003 F150
Jan 27, 2014 07:25 AM
bryanmartin
May 31, 2012 11:06 PM
topscrt
Jul 3, 2009 07:54 AM
nastruk95
Feb 26, 2006 12:28 AM
