Lund visor moves, normal?
Old Mar 28, 2020 | 10:07 PM
RedneckNate18's Avatar
RedneckNate18
Hello all, I have a Lund visor on my 1991 f150, Lately Ive noticed it has a lot of movement to to it after I reach about 45 and gets worse the faster i go. Im concerned the continued move
ment will make it crack and break. Upon inspection it seems to have a few cracks though i cannot remember if it was like that when i installed it years ago or if they are new and i also cannot tell if they are only paint deep or in the gelcoat and fiberglass itself. I dont think i ever saw it move before but maybe i just never noticed it. I took all the plastic caps off and tightened all the screws a little and that did nothing. In an older thread i saw that someone said that using a bug defletor with a visor can cause damage to it. I have a bug defector but the problem started before i installed the bug deflector so i dont think thats it but has anyone heard that before? If you have a visor does it move? And has anyone seen one break do to movement? Thanks and sorry for the very longwinded post.
Old Mar 28, 2020 | 10:20 PM
sandymane's Avatar
sandymane
When I removed mine when I bought the truck, from what I saw, your screws have probably loosened and you have enlarged holes causing the movement. You can just use a little larger screw or J B weld the holes and redrill them. There are plenty of clear cements that you can probably use to fix the cracks. I don't think the bug guard would cause that to happen but ? Mine had one on it also and I removed it. The visor was still tight but it had low mileage and was towing a 5th wheel. Sandy
Old Mar 29, 2020 | 07:57 AM
Broncor's Avatar
Broncor
I’m having the exact same thing happen, I have gone w larger course thread lags twice now.
I think I’ll take front trim inside cab and drop headliner then bolt the visor right through.
Old Mar 29, 2020 | 03:00 PM
RedneckNate18
So today, just for giggles i took the bug guard off and went for a ride. Problem fixed. Before it started moving at 40mph without bug guard it was rock solid to 65 before i saw any movement and than very slight movement beyond that. I got it up to 80 and only a slight tremor here and there, nothing like before so the bug guard is coming off for good.
Old Mar 29, 2020 | 03:06 PM
RedneckNate18
if you have a bug guard i would try removing that first as that fixed my problem. Also I dont think lags would be the correct mounting screw but rather a large sheet metal screw. I would think the lag threads would be too far apart and not grip the thin roof metal well.
Old Mar 29, 2020 | 05:40 PM
Broncor's Avatar
Broncor
lags weren’t my first choice, I’ve got the holes oversized now that’s what would fit and seem to grab. Definitely not the right choice.
Ive seen a product called a jack nut , insert that is on cab, thread into it and it expands up locking it tight.
I do in fact have a bug guard ..makes me wonder.
Old Mar 29, 2020 | 08:16 PM
torq'ta 5 8's Avatar
torq'ta 5 8
bug deflector wreaked havoc, on my wipers, took off no more issue, and you could try fine thread, they would give more area grabbing a hold of, than coarse threads
Old Apr 16, 2020 | 08:53 PM
Broncor's Avatar
Broncor
Redneck and Torq were absolutely correct.
Took off my bug deflector 2 days ago...no more visor moving around.
Thanks !
66ordie
Jun 26, 2020 07:57 PM
conrad10781
Sep 28, 2018 01:57 PM
nlemerise
Dec 26, 2011 07:43 AM
subiej
50
May 25, 2011 08:08 AM
Drewski 2
Nov 16, 2010 07:53 AM
