Beast mpg's
Old Mar 28, 2020 | 06:01 PM
DADDYFIGJAM's Avatar
DADDYFIGJAM
Beast mpg's
Took a little trip today to get essentials.85% highway/15% threw the city to get on another highway. Some stops and only one off/on key cycle(getting stuff). I'm quite happy with this 6.2 as it breaks in. The li-o-meter was still creeping up as I took this pic but was getting off the highway. Interestingly, I do get better mpgs at 60 than 55 in 6th gear. Must be because the rpms are at or slightly below1500 and then it becomes a matter of throttle input. This surprises me as Beast is so damn tall that speed hurts.also a view of the Gtrans temp.and finally a pic of the stock height of Beast.
Old Mar 28, 2020 | 08:10 PM
Nathan's Avatar
Nathan
I've seen similar from my '17 6.2 on the rare occasion I get it out on the highway. Sadly most of my miles are rural/ city so I'm usually in the 12-14 mpg range.
Nathan
Old Mar 28, 2020 | 08:23 PM
TCNashville's Avatar
TCNashville
I routinely get 16+ if I keep it under 65. Transmission temps usually hover in the 195* to 205*.
Old Mar 29, 2020 | 10:09 AM
DADDYFIGJAM
Yes, I think based on my actual gearing of 3.56, and wind resistance at speed, 62 mph is the sweet spot for mpgs. That speed changes with different gearing.
Old Apr 5, 2020 | 09:26 PM
mdodd84's Avatar
mdodd84
I’m averaging 17-18 doing my normal 13 mile route to work and back.
Old Apr 5, 2020 | 09:33 PM
ejb69's Avatar
ejb69
My 7.3 tremor is only getting 11.4 according to the display. That’s mixed driving.
Old Apr 5, 2020 | 09:46 PM
DADDYFIGJAM
If you don't mind me asking, what is your gearing and tire size. The reason i ask is, the 7.3/10 speed has been getting pretty good mileage since its inception.
Old Apr 6, 2020 | 06:25 AM
ejb69's Avatar
ejb69
pits a Tremors so ,4:30 with 35” tires it’s the only way they come. I was expecting to get better mpg than my 2016 f250 6.2. But that’s not the case so far . I’m expecting to get about 10 pulling my boat. But they now closed the boat ramps so it may be a long while before I find out. Some are saying they may not reopen boat ramps to July if at all this summer.
Old Apr 6, 2020 | 10:16 AM
RainDesert's Avatar
RainDesert
Are your tires the stock 275/70/18 ?
Old Apr 6, 2020 | 12:47 PM
2019er's Avatar
2019er
I got 19.6 on the lie o meter on about a 325 mile round trip recently. Mostly level ground, mostly 50-60 mph on country roads.
Old Apr 6, 2020 | 05:03 PM
DADDYFIGJAM
yes indeed.
Old Apr 14, 2020 | 09:53 AM
Central FL Mike's Avatar
Central FL Mike
Diesel Dum-Dum
I've been monitoring mine for the last few tankfuls. I jump to 18.3 sometimes but there is too much traffic and too many hills on my daily commute.
Old Apr 14, 2020 | 10:54 AM
Lamoon78's Avatar
Lamoon78
Where is this at.
Old Apr 14, 2020 | 04:54 PM
Scag_Driver's Avatar
Scag_Driver
I'm not following this. I understand the tire height change out gear ratio calculator. However OP is saying with stock 275 70's from the factory and his factory 3.73 is reduced to 3.56.
I thought with factory gearing whatever tire you get factory thats the gearing you run with until you change the factory tire size.
I had 4.30 with 275 70. According to OP I'm not running 4.30 in reality
Now I had 285 75 Geolanders put on which reduced my ratio to 4.09 from what i thought was correct
Old Apr 14, 2020 | 05:02 PM
acadianbob's Avatar
acadianbob
I think people are saying that it is all RELATIVE to the standard 275/65R18 tire. So, in a sense, and compared to that, your 275/70R18 is comparatively a 4.13 rear end if a 275/65R18 is 4.30.
Steelhant
Sep 3, 2017 06:22 AM
PowerStrokeJoe
6.4L Power Stroke Diesel
Aug 26, 2011 05:32 PM
novatattoo
Nov 2, 2010 09:07 PM
mvedepo
6.7L Power Stroke Diesel
Oct 12, 2010 10:35 AM
DAFBFD58
Delaware Chapter
May 18, 2007 06:39 AM
