Engine Swap Question
Old Mar 28, 2020 | 01:16 PM
OneFifty94's Avatar
OneFifty94
Hey guys,
Found a low km 1994 5l 302 complete engine I can get for almost free.
Want to swap it into my 1994 F150.
Truck I'm pulling from has the 4r70w auto trans and mine has the E4OD. They're both 94 with 302.
The block out of his 94 f150 should mount up to my 1994 E4OD should it not?
I cant see them designing two different 302 blocks to fit different trans bell housings. Considering there were at least 3 types of auto trans in the 89 to 96 range.
Can anyone confirm this? I really want to go get this thing and do a light rebuild and swap them. It's got 180k km original on it and was running 2 months ago before he parked it.
Thanks
Old Mar 28, 2020 | 01:29 PM
timbersteel's Avatar
timbersteel
Bellhousing is the same. Flexplates are not.
If you're gonna use the E4OD transmission, then toss the 4R70W flexplate in the scrap pile. Just reuse your E4OD flexplate. You dont want to get them mixed up and then have the wrong one on. There's no salvaging the transmission once its started with the wrong one installed.
Old Mar 28, 2020 | 02:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
300, 302 & 351W are all the same bell housing bolt pattern.
Old Mar 28, 2020 | 06:50 PM
OneFifty94's Avatar
OneFifty94
Ack
Yeah I'll be pulling the flywheel off with the block.
Once I get her up on my mount to start pulling it apart I'll toss the 4r70w flywheel right away.
When I swap the engines I'll put the one on my truck onto the rebuild.
Thanks guys! Good info.
Looks like I'm a get me an engine to rebuild!!
Old Mar 28, 2020 | 08:34 PM
torq'ta 5 8's Avatar
torq'ta 5 8
glad you found one so quick, you stroking your 302 now that you dont have to rush
emschris
Oct 28, 2014 05:05 PM
almford1992
Dec 17, 2010 01:59 PM
92_FlareSide
Aug 25, 2005 12:25 AM
CT
Sep 17, 2002 10:28 PM
