Blower Motor Problems....
Old Mar 28, 2020 | 12:57 PM
Tim Holmes's Avatar
Tim Holmes
Hello all! I have a 2013 F150 XTR and I am having this fan speed issue. Currently the control does not work (it is stuck on medium speed). When I turn the power to the HVAC off using the power button the speed will increase but stay on. I can stop the motor completely by shutting off the key. I do still have control over the different functions (floor, panel, defrost). I have tried to replace the blower motor resistor, but that cause it to not work at all. I have checked the relay (by replacing it with the rear window defrost relay which my truck doesn't have), and still the same outcome. I have searched all over the internet but all I come up with is the blower motor resistor.
Please help! And thank you in advance!
Tim
Old Mar 28, 2020 | 06:21 PM
steve(ill)'s Avatar
steve(ill)
did you look real good at the electrical plug for burnt wires / crud when you changed the resistor ? Why would it stop working when you switched resistors ?
Old Mar 28, 2020 | 06:37 PM
Tim Holmes's Avatar
Tim Holmes
https://www.youtube.com/watch?v=3hHxAiKvw2o
I did, and found nothing. The connector and the old resistor are both good. No corrosion, or burnt connectors. I was wondering the same thing about the new resistor. When I put the old one back in it goes back to doing what it originally did. New resistor, no operation at all. I also saw that video and I do not have that issue.
Old Mar 29, 2020 | 11:14 AM
alloro's Avatar
alloro
Manual or automatic climate controls?
Old Mar 29, 2020 | 11:37 AM
Tim Holmes's Avatar
Tim Holmes
I have manual climate controls, however the resistor is the larger one with the white plastic housing (i believe this one is for the automatic controls, even though that is not what I have). My controls look like the YouTube video that is in this thread.
Old Mar 29, 2020 | 11:42 AM
alloro's Avatar
alloro
What about a bad speed selector switch on the dash, have you tested it?
Old Mar 29, 2020 | 12:24 PM
Tim Holmes's Avatar
Tim Holmes
I followed a video to check the output voltage, and I think I was checking the duty cycle as well (not sure if I was doing it correctly though). The video said there should be a 0-5 volt demand when you go from low to high speed. I had supply voltage, but I couldn't get duty cycle voltage. Again I am not sure I was doing it correctly. I am just confused as to why when I replaced the resistor it didn't work at all though. I would think that if the control was bad it would be bad either way.
Old Mar 30, 2020 | 08:25 AM
rbentnail's Avatar
rbentnail
Have you ohmed the resistor to see if it's good? Maybe someone gave you a diode instead.
Old Mar 30, 2020 | 07:34 PM
projectSHO89's Avatar
projectSHO89
Does your speed control selector have four or seven positions?
Have you scanned the EMTC for any fault codes?
StadEMS3
Jan 13, 2019 08:40 AM
sorg76F250
Aug 28, 2018 03:41 PM
Poochs
Jul 11, 2017 08:04 AM
Sgt Wonderful
Oct 10, 2006 09:41 PM
