Window motor
Old Mar 27, 2020 | 01:10 PM
Powerstroke.Alix's Avatar
Powerstroke.Alix
Window motor
Anybody have any advice on replacing the driver side window motor?? This seems to be a harder job than i had thought LOL on that note, any help is appreciated!🤙
Old Mar 27, 2020 | 03:19 PM
farmert's Avatar
farmert
It is not that hard of a job, but you will have to drill 3 holes in the door shell if the window motor has never been replaced. First remove the inner door panel. There will be a dimple in the door sheeting in 3 places where you will drill the holes. I think I used a 1/2 inch bit to do so. after the holes are drilled you can reach the bolts that hold the motor on to the regulator, threw said holes. Use a 1/4" drive socket and an extension to reach said bolts. The replacement motor may need the plug end on the wires transferred to it from the old motor.
Old Mar 28, 2020 | 08:07 AM
Powerstroke.Alix
Okay cool i got that far, i got the bolts out of it i just have no clue how to get it off of whatever shes stuck on.... Lol PITA!
Redneckfordf2502002
Sep 27, 2023 05:05 PM
PsD007.3
Nov 15, 2009 12:15 AM
*2fords*
Jul 17, 2009 01:24 PM
1fordtruckman
Oct 22, 2007 07:44 AM
shadetree mech.
Nov 22, 2005 03:17 PM
