Speedometer Jumping
Old Mar 26, 2020 | 09:39 PM
keithoscott's Avatar
keithoscott
Speedometer Jumping
1994 F250
7.3 Turbo IDI
255k miles
2wd
5spd manual
Problem: Speedometer works up to 35mph then needle becomes erratic. Within minutes, speedometer and odometer stop working entirely. All other gauges continue to operate normally.
Solutions I’ve tried: Replaced speed sensor on rear axle with generic Dorman brand - no change. Replaced speed sensor with OEM - no change. Replaced rear axle gear oil and cleaned gears throughly before refilling with Ford recommended oil/cleaned OEM sensor - no change.
Am I just screwed? I’m selling truck and REALLY don’t want to spend $$ anymore. Drained nearly 8k in the last 3yrs, no exaggeration...
Old Mar 26, 2020 | 10:42 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
possible bad Caps on the PSOM PCB
Problem areas marked in Red...
DCGuillory
Aug 6, 2017 05:06 PM
MBDiagMan
Large Truck
Feb 6, 2016 07:35 AM
Shanemh
Jan 19, 2010 05:43 PM
RedneckRampage
Nov 5, 2009 08:45 PM
djtech
Jul 20, 2006 08:32 PM
