speedo acting strange then gear hunting - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 08-06-2017, 11:42 AM
DCGuillory
DCGuillory is offline
DCGuillory is starting off with a positive reputation.
Cant find anything on this with search.
After about 25 mins of driving the speedo starts bouncing around a little for about 10 mins. Then the speedo stops working all together and the transmission starts hunting for gears but I still have power. I dont have a way to pull codes atm. I will get them asap. I assume this is a sensor issue. Anyone know where I should look for something partially hanging off my rig or corroded or something?
All fluids are recently changed and I did check that they are full.
Basic current and ground checks out okay.
I turned the tuner off before I started driving to see if that would help, no dice.
2000 E350 7.3 425,XXX miles
Old 08-06-2017, 05:06 PM
EagleFreek's Avatar
EagleFreek
EagleFreek is online now
EagleFreek is starting off with a positive reputation.
The speed sensor is located on the rear axle. It is probably in need of a new one or there is probably metal shavings in your rear axle messing it up. I would start with changing your rear axle fluid and removing your old sensor and cleaning it. There is also a tone ring in the differential that can go bad.
Old 08-06-2017, 06:06 PM
DCGuillory
Thanks Rick. Sounds like basic good advice. I will do both.
Drcoolhand
03-17-2008 07:50 PM
1989f250lariat
18
02-24-2007 09:17 AM
jetjock16
1999 to 2016 Super Duty
13
12-19-2004 07:15 AM
jetjock16
25
12-06-2004 09:17 PM
83F-250OWNER
16
03-09-2003 04:45 AM
Quick Reply: speedo acting strange then gear hunting
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
