Door moldings causing huge door gaps
Old Mar 26, 2020 | 06:03 PM
bbf150's Avatar
bbf150
Anyone ever had this problem with aftermarket door moldings ? I had a big gap in the ps, stripped interior to paint, put the moldings back on and now I have a huge gap in ds so I must have flip flopped them-irritating as …. !
Old Mar 26, 2020 | 07:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The year and model is? Where are the mouldings located?
Old Mar 27, 2020 | 09:13 AM
bbf150's Avatar
bbf150
'77 F150 standard cab-door opening moldings that go around the cab that sill plates bolt down on, aftermarkets bought from Bronco graveyard
Old Mar 27, 2020 | 10:04 AM
lafermedavid's Avatar
lafermedavid
I believe you mean weatherstrip rubbers,,,,I had my door interior panels off,,I put a ratchet strap across the two doors and snugged lightly and let sit for a good while ,,it will conform
Old Mar 27, 2020 | 11:44 AM
bbf150's Avatar
bbf150
Good idea-were your doors hanging out far as well i take it ? Did you take your door latch striker plates off ? How long did you leave it sit ?
Old Mar 27, 2020 | 01:42 PM
lafermedavid
yes i did and it sat at least two weeks,,,giving it a little tension at a time
Old Mar 27, 2020 | 02:55 PM
broktruk's Avatar
broktruk
Whats the weather like where you are? Probably difficult if its cold/cool outside. Remember how soft a garden hose is after being in the sun for a while? Thats what i have to remember when trying to mold hoses and weather stripping.
Old Mar 27, 2020 | 04:18 PM
lafermedavid
you bet heat helps
Old Mar 27, 2020 | 07:47 PM
bbf150's Avatar
bbf150
Maybe i need to break out the heat gun or let it sit in the sun with the doors open-the moldings have been sitting in my concrete garage all winter, the temps would be lucky to be 50 in there
Old Mar 27, 2020 | 07:50 PM
bbf150's Avatar
bbf150
[QUOTE=lafermedavid;19194079]yes i did and it sat at least two weeks,,,giving it a little tension at a time[/QUOTE
So you didnt tension them up fully closed right away-where did you run them through and did you use the straps running through the door or hook them ?
dairydude
Mar 22, 2020 08:12 PM
Pebcak
18
Sep 29, 2016 01:03 PM
