door weatherstripping
Mar 20, 2020 | 11:53 PM
Who has a good quality door weatherstrip for a 56?
Mar 21, 2020 | 02:19 AM
I bought mine from LMC and it fits perfect.
Mar 21, 2020 | 04:25 AM
Steele Rubber or Dennis Carpenter both sell high quality rubber.
Regards, Mark
Mar 21, 2020 | 06:18 AM
Dennis Carpenter, When you glue it on tape it in place as you go every 3-4" to hold it in place till the glue dries.
Mar 21, 2020 | 07:41 AM
Don’t want to highjack your thread, we are going to be doing this soon and wondering if there is a specific glue for installing the seals.
Thanks
Mar 21, 2020 | 08:33 AM
Quote:
Originally Posted by
SumDayDryvr
Thanks
3M black adhesive
Mar 21, 2020 | 08:46 AM
Thanks Abe. We did get the hollow style from Midfifty.
Mar 21, 2020 | 09:56 AM
X2 Learned from experience! Follow the instructions Apply on both surfaces, let tack, install.
Mar 21, 2020 | 10:05 AM
bjmayberry2
Very important to let tack. Then you don't need to tape it.
Mar 21, 2020 | 10:42 PM
I have done this many times and as was previously stated, you should not need tape if you are patient and let the glue tack. Another bit of advice is to use a very thin layer of the glue and not a thick bead. I use an old plastic bondo spreader and cut it into strips to use for spreading out the glue on both surfaces.
Mar 22, 2020 | 08:12 PM
ajbrown208
28
Mar 25, 2020 07:35 PM
jvmcc
Jan 2, 2016 03:28 PM
Joker50
May 28, 2008 03:29 PM
FordPickup460
May 22, 2005 10:41 AM
