Oil leak
Old Mar 25, 2020 | 08:08 PM
Erick Garcia's Avatar
Erick Garcia
Oil leak
Diagnostic
I have a small leakage of oil coming from the motor. It only leaks from the corner of the motor on each side. It’s a 2017 Ford F-250 6.7 with 108k miles any ideas what could be the problem?
Old Mar 25, 2020 | 08:29 PM
Just Strokin's Avatar
Just Strokin
Have you checked to see if the turbo mount might be leaking? The engine does feed oil to the turbo through the stand to cool the turbo bearings.
Old Mar 25, 2020 | 08:37 PM
Erick Garcia
i haven’t checked that. But the leak seems to be coming from the motor itself? Maybe a bad gasket?
Old Mar 26, 2020 | 04:28 AM
Just Strokin
Hard to imagine a similar oil leak on both heads? I would look for a common area that might leak and the oil drain down both sides of the engine.
Old Apr 2, 2020 | 01:14 PM
TeddyD's Avatar
TeddyD
I just went through this. It is most likely a leak from the upper oil pan. The robots did not put gasket sealer on the corners of the pan. On my truck, a quick lube guy noticed the leak first and said it was the main engine seal leaking but when diagnosed by the dealer later, it was the oil pan. I did not notice any oil on the ground at all but when I did, I sent it to the dealer. The transmission has to be removed to do the repair. Mine was under warranty but the dealer billed around 15hrs of warranty labour. Link for the repair process below. Very good possibility that this is your problem.
The day after the dealer returned the truck, I had another oil leak. The dealer did not seal the lower oil pan properly and that was quickly resolved. Good luck.
Dwightttt
Mar 23, 2016 10:27 PM
jwlsbaldwin
Feb 12, 2015 06:03 PM
xbigbuckleyx
Jan 2, 2010 07:05 PM
derekmj64
16
May 6, 2008 08:53 PM
TN Hillbilly
Mar 13, 2005 09:59 PM
