94 F250 5.8 I have replaced the egr solenoid cleaned the egr. It is like it shifts when driving on highway when I pull the vacuum hose from egr it rums good but dies at low speeds. Any help would be appreciated
crap! my bad, use this while looking at post#2 pics, jaloppy made laptops!
The terminal pins are as follows:
• Voltage Reference (5v from the EEC) • Signal Return (Sensor Ground) • EVP Signal (Varying voltage to the EEC)
Testing parameters are as follows:
• Reference Voltage (5v at pins VREF and SIG RTN) • EVP Sensor Resistance (< 5000 ohms at pins VREF and EVP) • EVP Sensor Resistance (> 100 ohms at pins SIG RTN and EVP)
