334 code
Old Mar 24, 2020 | 11:44 AM
steveamann's Avatar
steveamann
334 code
94 F250 5.8 I have replaced the egr solenoid cleaned the egr. It is like it shifts when driving on highway when I pull the vacuum hose from egr it rums good but dies at low speeds. Any help would be appreciated
Old Mar 24, 2020 | 05:17 PM
torq'ta 5 8's Avatar
torq'ta 5 8
test EGR, see if its closed, it should only open at steady/constant speed
Fuel Injection Technical Library » EGR Valve Position sensor (EVP)
Old Mar 25, 2020 | 08:12 AM
steveamann's Avatar
steveamann
How to check voltage on the egr and solenoid?
Old Mar 25, 2020 | 06:57 PM
torq'ta 5 8
crap! my bad, use this while looking at post#2 pics, jaloppy made laptops!
The terminal pins are as follows:
• Voltage Reference (5v from the EEC)
• Signal Return (Sensor Ground)
• EVP Signal (Varying voltage to the EEC)
Testing parameters are as follows:
• Reference Voltage (5v at pins VREF and SIG RTN)
• EVP Sensor Resistance (< 5000 ohms at pins VREF and EVP)
• EVP Sensor Resistance (> 100 ohms at pins SIG RTN and EVP)
DDBTX
Oct 26, 2017 04:39 PM
aka rotten
1983 - 2012 Ranger & B-Series
Nov 23, 2007 09:43 AM
rochs77
May 29, 2007 09:34 AM
brandon0011
1997 - 2003 F150
Feb 25, 2007 11:13 PM
paradiddle
Dec 26, 2003 08:33 PM
