LOHTO, A FUNNY LOOKING LIL ALIEN GUY JUST SAID to me, "THE FUNNY LOOKING THING ATOP THE stick WILL NEVER WORK very well." ... thas what it said" Shape it like a Saucer, that's what he said. It will re-enter properly then.
Who cares how many motors it takes to lift off and reach orbital speed, its got to Be a flying saucer to get it right. All else is just a waste of time. How many years have Flying saucer UFO's been around.
Apollo knew the spaceship had to have a Saucer design. Nothing else is worth the time of risk. Sure, building on the moon makes perfect sense. Easier to put them flying saucers into deep space from there.
Deep space exploration is probably a Gamming play with taxpayers, their monies and it needs the world to join in with their abilities instead.
Landing Boosters was a no brainer. Add a couple of motors and more fuel and Bingo. The rest is just a waste of money most likely just because it is.
Yes this pic seems about right and it propulsion may be invented. The rest may be just Greed until that propulsion is happening. Of course, the Crew area will be above the entry part and probably higher in the picture. Who cares the Heat Shield is the curvature of the design. It doesn't take an engineer to see that is what's going to work forever / Dissipates the heat the best over the easiest area and slows down the fastest. Sure, It's a heck of a ride you Alien guy. There simply are not Force fields B.S. in the next 1000 years of future and mostly like 10,000 years. Of course, this space craft will easily be lifted from the moon's surface 500 yeas from now most likely. U no its been over 50- years since we were on the moon's surface. Hurry?
I been reading about a recent study that suggests by 2050 the Gulf Stream Current Will Collapse.
That means the Northern Hemisphere will grow a lot of Ice piles. Duh, isn't the earth supposed to have a lot of ice.
So many move to the southern Hemisphere? Not, they can easily grow their own. Aliens Habitat the far north rapidly falling in numbers.
Russians drill for oil and NG in Antarctic. Polar Bears a smiling.
Can we just go with CRAZY ... ... Everything is a moving, and it will never be what it once was.
If you could go back in time the stuff wouldn't be there. It will never be there. It's done went. It's just Sci-fi.
Even if the Universe were to contract it wouldn't return to what it once was. Most likely the "We're missing
it by at least 2% is ??? not so accurate ???" Is The abundance of light Wave / Microwave energy released
since the beginning or whatever, all the way out there in all directions sort of making extra room? What
Does that actually mean? The passage of time & the speed of light across something being created out there.
The light acts like a wave or a particle. No Mass, just energy. Reason Solar works Light to Electrons. Why should
It take many decades for a photon to leave the Sun? Duh, it keeps changing. Whataver it is Dark light, Red light,
Blue light, whatever it keeps changing. What if Dark light never changes, never reacts with nothing, it just goes
& Goes forever. Constantly forcing more space Faster and faster cause there is more and more of it. What
kind of time would Dark Light be in? It Won't react with nothing, just causes more space time to happen.
Would it make sense to say it masses out there at the very edge of Space Time ? Forever expanding.
Sure you can't be there observing it. That would be Crazy.
Think of the surface of a balloon constantly expanding cause you are blowing air into it instead of Light energy.
So Light Energy / Dark causes the same thing with Space Time, constantly expanding stuff away, and more energy constantly being released.
The surface being space time & the stuff there at the surface expanding away from everything else. Except there are no Surfaces, just space time.
It just keeps going faster apart cause there is more and more space time. CRAZY RIGHT OR LEFT ?
But what if the Universe isn't only a sphere like oddity but, what if its a cylinder and an Oval. Now you have Length "Width and the Circular Pi
to figure with maybe an out of round structure everything expanding being stretched. The fabric of space time being stretched every which way.
Not just left or right, up or down but inside itself, ripped one might think.
Gravity, molecular adhesion, Weak Force, strong forces, that sort of stuff has no meaning in Space Time. Space time is now - the future, no past exists.
Time passes differently depending on, but Space Time only speeds up the creation of more room for it to pass in.
Sure that is why Matter has to keep happening because of the increase of Space Time.
Believing the Matter in creation was the same as in the past would also be CRAZY !
There isn't a definition of Insanity or Sanity coming with all that stuff.
Stretching out the universe the observed isn't in real time. All that has long long passed by in time.
All you see is the very far past in your prospective. It's not now or the future there.
If one could get way out there to observe that stuff, things here would be lucky to still be just a Cinder.
More likely so far spread out as not to exist as any normal matter anymore, more stuff added to space time.
Think of a gnat in flight. You can observe many more in flight, some may seem the same flight but you never
see that same gnat making the exactly same flight you just saw. Maybe a different gnat but that's not the same.
Of course you may have video of it but thats not time travel. Its just a picture show. Look at the moon, you are
not seeing it in real time, you are seeing the light that has arrived from reflecting off of it. Stretch out to Mars.
3 Minutes to 22 minutes approximately in the past is what you are seeing.
------------ How Did The Universe Expand To 46 Billion Light-Years In Just 13.8 Billion Years?
The reason Deeper than the Solar system space travel is sort of Crazy! Of Course, the Moon Has huge meanings for the future of the Earths Humans!
Life in every galaxy is dependent on itself. The Universe expansion is at unlimited areas because what else is out there to slow it. You know Unlimited Area
doesn't / shouldn't give a dam about what's inside it. Unlimited area only cares about the uncolorable speed of continual growth of itself. BINGO It got the fuel.
Many very inteligent men and woman have said the univers when observed from different angles appears to be flat.
1st. the orbit of the Earth around the sun is mostly flat. the orbit of the Sun around the Galaxy is mostly flat, the orbit of the Galaxy is mostly flat.
So the Universe's shape is most likely some kind of an OVAL. Look out there, every direction everything is a Ovular Ball. All of gravity is circular.
Light bends passing gravity. Trust in a ball (circular, oval reason of everything) ... JHC ... . Sure light / microwaves tend to travel in a straight line but
It bends with Gravity and Its going in absolutely every direction possible also. Space expands cause it has to in all directions.
Easy to get the understanding that light exists in space and time and that space / time is expanding at the speed of light. In all dirrections.
so He said let there be light and Space Time has existed and constantly expanded
across an oval at the speed of light since forever and only the future can happen.
Why should anyone in their right mind believe there are other universes out there just like ours.
Ladies they got their own ideas on that. Lets just go with un-believable empty space cause of expansion or ours.
U have two survivors: Asian / African / Western Europe 's 50% --- *** North American / South American + western Pacific Islands and Australia?
Does anyone else see that? With out Nunc Arl war? 7 billion to 1,ooo,ooo,ooo !
Of course it won't go that a way till much later. North against the south, East against the west. Total Crazy is the near future.
