Backup Camera Staying On
Old Mar 22, 2020 | 03:00 PM
wing-2's Avatar
wing-2
I just moved my truck in and out of the building to remove the plow. The camera stayed on after shifting into drive. I t stayed on until I shifted into park. Any idea why?
2017 F 350 XL Regular Cab. Ultimate camera package.
Thanks.
Old Mar 22, 2020 | 03:56 PM
Hawk328's Avatar
Hawk328
It will stay on until your forward speed exceeds a set amount...I believe 5mph.
Old Mar 22, 2020 | 04:08 PM
TeddyD's Avatar
TeddyD
Backup camera should turn off as soon as you leave reverse but the front camera, if activated, would turn off around 5mph.
OP, that’s weird. Just keep an eye on it to see if it happens again.
Old Mar 22, 2020 | 04:17 PM
ForCal's Avatar
ForCal
There is an option that makes the reverse cam stay on(delay)for a few, after shifting into drive. You can turn that off in the settings.
Old Mar 22, 2020 | 04:46 PM
TeddyD's Avatar
TeddyD
Inwas wondering what that delay option was. I have never turned it on. 👍
Old Mar 22, 2020 | 04:58 PM
Heathmc's Avatar
Heathmc
I find it very useful with trailers to be able to easily see the movements when changing directions.
Old Mar 22, 2020 | 05:18 PM
75Mike's Avatar
75Mike
This. Nice that it stays on when you are "jick jocking" your truck to line up on your trailer coupler.
Old Mar 22, 2020 | 05:25 PM
TeddyD's Avatar
TeddyD
Exactly what I was thinking. I’ll have to turn that delay on.
Old Mar 22, 2020 | 08:36 PM
wing-2's Avatar
wing-2
Cool. I must have changed that setting without knowing it. Good to know. Thanks very much.
Old Mar 23, 2020 | 12:36 PM
GABAR's Avatar
GABAR
Thanks.
How long does it stay on?
Old Mar 23, 2020 | 12:38 PM
75Mike's Avatar
75Mike
You didn't go over 5 miles an hour for it shut off in drive.
Old Mar 23, 2020 | 03:39 PM
wing-2's Avatar
wing-2
I actually left the yard today. It quits at 5 mph. I was unfamiliar with that setting. I thought there was a malfunction. Thanks again.
Old Dec 22, 2020 | 06:17 PM
cficare's Avatar
cficare
Waking an old thread. This issue recently started to happen with my '17 KR ... rear camera would remain active on screen until I hit 5 MPH. It never did that until recently. After reading some posts above, I realize this probably started when I towed a rental stump grinder ... was the only time a trailer has been connected to my truck. And thinking back, that's probably when the camera started remaining on. Gonna' go look at my tow settings. Thanks for your discussion!
EDIT TO ADD: After a brief bout of frustration not finding an applicable setting to change among the dashboard's towing menu options, I resorted to searching the owner's manual (thank God for electronic copies) to find the setting must be changed in the SYNC panel. All is back to normal. Thanks again!
Old Dec 24, 2020 | 03:22 AM
wing-2's Avatar
wing-2
Mine had taken to staying on again, and I could not find the setting. I was plowing snow at the time, and could not get logged onto this forum on my phone. I ended up getting help in a facebook group. My error was not swiping the screen to get the next page of icons that included the camera setting.
S26921E
Oct 10, 2011 06:32 PM
dalton1000
May 7, 2010 07:48 PM
tonylugs
2004 - 2008 F150
15
Nov 4, 2008 06:11 AM
onebaddog
Nov 11, 2006 08:37 PM
RyanGruhn
1978 - 1996 Big Bronco
Feb 24, 2003 10:40 AM
