Sponsored by: Real Truck
4x4 switch mod
Old Mar 20, 2020 | 10:50 AM
2000f3501ton's Avatar
2000f3501ton
4x4 switch mod
Trying to do a search for using a toggle switch for 4x4 activation. Cant find anything. Have heard about this mod, just need some info on it. It's either this or swap a manual trnsfercase in, and I'd rather try the switch first. Any info on how to go about doing it would be appreciated. I know you need the wires from under the hood, from the relay, a brown/black and orange and a yellow and black?
Old Mar 22, 2020 | 04:06 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Are u trying to do the low range 2wd mod?
Old Mar 22, 2020 | 04:09 PM
2000f3501ton
No I'm not. Just for all 4x4 use
Old Mar 22, 2020 | 10:04 PM
SuperDutyScaler
So why add a toggle when the dash switch is there already?
Old Mar 22, 2020 | 10:08 PM
2000f3501ton
Because the dash switch doesnt work. Doesnt even light up. New shift motor on tcase. Could be many different issues so I just want to bi-pass it with a toggle. Thought I might get the info here, guess I'll just have to google it
Old Mar 23, 2020 | 12:58 PM
madsonp's Avatar
madsonp
I had a similar issue a number of years ago on a 1999 Expedition I used to own, it ended up that some wiring got damaged underneath it by rocks getting kicked up, here's a thread I wrote up about it years ago, however the pictures have since disappeared, might be something worth considering. https://www.ford-trucks.com/forums/8...ow-issues.html
88f1504x4
Feb 9, 2014 04:20 PM
Biggg72
May 27, 2011 10:37 AM
WALJON
Dec 26, 2007 09:40 AM
powerstrokeddiesel
13
Oct 20, 2007 12:14 PM
RickyBR
Oct 10, 2004 07:13 PM
